Question about Dryers
There is no heat coming from my dryer, just cold air! I have cleaned the filter, emptied the water and generally checked everything. Is there anything else I could try? Thanks Sue
  • 10,319 Answers
The piping of the entire venting can be plugged as well. did you clean that?
Posted on Apr 04, 2011
Dryer won't stay hot through the cycle
First make sure lint filter is clean. If filter clean check the exhust duct it may be full of lint or kinked blocking air flow. If everything checks out ok the problem is electrical. Dryers have a high temp switch as a safety shut off.
Sep 10, 2017 | Dryers
Hotpoint condensing dryer model TCFS93BGP. cleanfilter/empty water light keeps coming on after 3/4 minutes
Hi, my dryer has 3 things to check out of which one is more hidden:
- empty the water reservoir
- clean filter in the door
- clean condensor which is hidden below the bottom panel which has to be released through a button behind the door
The last one is less obvious and more difficult to find/reach. Might need to consult the manual.
Did you check all 3?
Hope this helps
Mar 25, 2016 | Hotpoint Dryers
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
The dryer the cheapest electric dryer made by roper just blows cold air duc is clear filter is clean everything works should i start by checking the heating element or coil hunter19-46m gave me good...
well, may be the heating element: here is the website. maybe something else like the thermal fuse, Good Luck Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Apr 17, 2011 | Dryers
I have cleaned out the vents to my dryer. And it still will not dry in one cycle. It takes 3 to 4 cycles before it will dry. It tumbles the air is strong and hot in the back
Hi.
Check if there is heath. If air is completely cold, check the heating element (in case of electric dryer). Heating element is tested removing it from appliance and reading Ohms with a multimeter to ensure it has continuity.
If there is heat, or if air is cold and element is good, test and replace the thermostats, there should be two or three of them placed in heating group and air ducts.
First ensure you have checked filter, vents and duct and removed lint.
If you want to contact an authorized technician call the number listed on the owners manual or on manufacturer website.
Jun 27, 2010 | Dryers
My tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Apr 13, 2009 | Dryers
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Not heating up
I would check the thermo fuse in the back of dryer.. its on the burner towards the top.. use omh meter and check if its good. If you dont have a meter, if very careful and just hook wires togeter and tape so nothing touches and will not short out by touching anything, bypass switch JUST to see if switch is bad! Replace it if bad
Sep 05, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
