I've LG 42ld450 television with cable tv connection. i don't have any problem with video but problem with Audio. i'm using auto tuning option for get the all channels after got channels i only got videos but not audios. after check the manual option don't find BG option in system. one of my friend using same TV but he got this option of BG in manual turning and i can't changed it to Stereo. need your help!
rebel_245
  • 24 Answers
SOURCE: [MSI 8606 TV Tuner Card] Can't get a picture
here is a link for the driver, http://drivers.softpedia.com/get/TV-Tuner-Co/Others/MSI-TV-Tuner-Master-8606-WDM-279165.shtml
Posted on Mar 29, 2007
skipper360
  • 58 Answers
SOURCE: sylvania 6432td 32" screen
You have to choose the right INPUT on your TV where your DVD player was connected. If your using the Yellow/Red/White cable from your DVD player you need to choose on your TV the input Example Video1 Video2, etc... If your using the COAX,(like cable wire) Put your TV on Channel 3 or 4. Hope this may help you. Please post the outcome, if you need further help. Is this TV is a COMBO?
Posted on Aug 13, 2007
bkvinr
  • 76 Answers
SOURCE: Sanyo TV - DS25390
In your model you have to purchase one video RF converter. RF converter contains one video input in yellow colour and two audio input in red and white colour and one cable connector as output. Connect the dvd output to this converter and tune the tv program in which place you receive dvd signal.
Posted on Aug 27, 2007
  • 11 Answers
SOURCE: VCr connection
should be a source button so kind on the remote or on the tv
Posted on Nov 24, 2007
jsinex2421
  • 62 Answers
SOURCE: CONNECTING MY TV TO MY STEREO
Make sure the output in your tv menu is set to external speakers. Any digital optical cable, or RCA jacks hooked up properly from the TV's out put to the receivers input should work just fine. Take your time, retrace your steps, and make sure each cable is in the correct input/output. And make sure the receiver and TV are on the proper settings. Good Luck, and thanks for using FixYa!
Posted on Jan 13, 2009
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
I connected a speaker bar directly to my new LG TV. The speakers came with two audio cables ( red & white) and one video cable (yellow). I connected the red & white cables to both devices - red...
You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
Aug 29, 2011 | Audio Players & Recorders
I have a LG 42LD450, I read and saw videos online showing that you can enable video playback through the USB port. I also read that u need a certain universal remote to access the service menu does anyone...
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
Dec 04, 2010 | LG 42LD450 42 in TV
I would like to connect my LG42LD450 to my Pannisonic surround sound system but the audio out on the tv is digital and my sound system audio in is an standard plug. what can I do. John
Contact one of the electronic stores and see if they make these cables that you can adapt to the older style. I have a converter box on one of my tv's that I can hook up to the old style plug ins and it works fine, got it at Radio shack.
Nov 24, 2010 | LG 42LD450 42 in TV
When I power on the tv, I have sound but no picture.
is the video cable connected in the correct spot? are you using HDMI? RBG?? Make sure if you are using RGB that they are in the correct spots on the tv and the output device!
Nov 21, 2010 | LG 42LD450 42 in TV
I got an American model of LG. i can not tune it by auto nor manual can you please help
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
I hope this helps.
Nov 05, 2010 | LG 32LG30 32 in. LCD HDTV
Sky remote code for lg 42LD450 42
hi code is 0206 works fine with mine
May 24, 2010 | LG 42LD450 42 in TV
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
