Question about Haier Rhapsody (4 GB) MP3 Player
My haier ibiza's half display flicks - Haier Rhapsody (4 GB) MP3 Player
I have a Haier dryer and it just clicks but won't come on. This happened one other time and the repairman said it was the reset button. Where do you find the reset
FIRST SEE IF YOUR OUTLET HAS ELECTRIC IF SO KEEP FLICKING THE ON BUTTON NUMEROUS TIMES IF U R MECHANICAL OPEN DRYER CHECK TO SEE AT ON SWITCH IS GETTING JUICE IF IT IS GET A NEW DRYER
Jul 14, 2016 | Haier Dryers
My Ibiza is frozen. Will not charge either. Help!
Did you try pushing the tiny reset button on the bottom right side of the player?
Feb 11, 2011 | Haier ibiza Rhapsody H1B008 Digital Media...
Video downloading
download mp4 videos
if you want to search and download music or videos,i think this is helpful for you .
Jun 07, 2010 | Haier ibiza Rhapsody H1B008 Digital Media...
IPhone Smartphone: cant charge iphone in ibiza battery went flat...
Possible solutions
1. buy an adapter for your charger
2. plug it into a computer
3. provide more details than you have so far...
can't charge iphone is a vague way to explain your predicament...
can't charge or won't charge?
can't get an adapter?
don't have access to a computer?
Half solution, half clarification request...
May 16, 2010 | Apple iPhone Smartphone
My ibiza rhapsody is showing up as a camera on XP and subsequently isn't recognized by Real Rhapsody. I've uninstalled and reinstalled the device with no luck. The solution posted on this through another...
this worked for me but I got it from some one else, good luck!
"Ok I think I figured it out.. With the mp3 player connected via USB, go into the device manager and it should be listed under imaging devices. Right click and select 'update driver', 'no, not this time', 'Install from a specific location' and 'Don't search, I will choose which driver to install'. From there, you should be able to select MTP Device. This corrected my problem and I hope it helps you, too. Good luck!
-Michael"
Mar 30, 2010 | Haier ibiza Rhapsody Digital Media Player
My music shows on the computer but I can't access it on the mp3 player
u said it urself mp3 player u have to find out if the music ur tryin to put in is in a mp3 format their is lots of audio formats and an mp3 player kant read them
Mar 07, 2010 | Haier ibiza Rhapsody Digital Media Player
Will an Ibiza still download if it's turned off?
As long as it is connected to the computer via a usb, yes.
Feb 12, 2010 | Haier ibiza Rhapsody Digital Media Player
My ibiza is not showing on the rhapsody software rather my system recognises it as a camera device.ive tried just about everything and im not sure wat to do. please help??
right click your my computer, hardware tab, go to device manager, right click your ibiza and you can change it to a mp3 under properties
Jan 13, 2010 | Haier ibiza Rhapsody Digital Media Player
Will not turn on. this mp3 player has been on the charger all day
it may happen that the battery itself is brocken!!because it is over charged you said that its been charged all day...that might be the problem because if its over charged then theres a possibility that it wont be turned on or wont work..try changing the battery and try to turn it on..
May 18, 2009 | Haier ibiza Rhapsody Digital Media Player
Haier Rhapsody (4 GB) MP3 Player Logo
Top Haier Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Haier Audio Player and Recorder Expert? Answer questions, earn points and help others
