Question about Canon PIXMA iP4000 InkJet Photo Printer
Print Head Holder
The print head holder is locked.  It will move to the right after ink tank was replaced.
As you suggested, I unplugged the printer and left it off for a few minutes.  That did it!
Posted on Aug 06, 2008
HOW CAN I REMOVE THE PRINT HEAD ASSEMBLY ON A CANON MX340?
Follow the given steps:
1. Confirm that the printer is powered on.
2. Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
3. After confirming that the print head holder has moved to the center, open the inner cover.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 12, 2012 | Canon PIXMA MP130 All-In-One InkJet...
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
Dec 03, 2010 | Canon PIXMA iP1300 Printer
How do I find and remove the printhead?
Here you go:
8. Close the inner cover and top cover. __________________
"If it's really a supercomputer, how come the bullets don't bounce off when I shoot it ?"
Jul 09, 2010 | Canon Office Equipment & Supplies
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma IP4000 cyan ink will not flow even though I have repeatedly cleaned and deep cleaned and replaced ink tank.
If you have gone through the process of cleaning and deep cleaning, as described by canon, and you still get no ink flow after printing 2-3 pages, the print head needs to be replaced.
Here is WHO to contact and HOW to install the print head:
WHO: Purchasing a Print Head
You may purchase a print head* for this printer by calling 1-800-828-4040 Monday-Sunday 8:00 a.m. - 12:00 midnight. EST, excluding holidays. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance. Be sure to have your model number (iP4000R) or part number (QY6-0049-000) ready for the sales person.
HOW: Install the print head and ink tanks correctly iP4000/iP4000R/iP5000
    Properly installed:
Feb 08, 2010 | Canon PIXMA iP4000R InkJet Printer
Can't find ink storage
look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
    i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from the silver package.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  4. Remove and discard the orange protective cap.
  5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
  2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  3. Install the Ink Tank
    Press the PUSH mark on the ink tank until it clicks into place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a well-lit environment
    i_important.gif Important : Match the labels when installing.
  4. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important : Make sure all the Ink lamp lights red.
  5. Close the Scanning Unit (Cover) (B).
Mark
Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
I cannot remove the printhead to install a new one , afrain of breaking somethin
1.Confirm that the printer is powered on.
Nov 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Just bought new ink for my printer; Canon MP510 it says it cannot recognize magenta....it is the correct one CLI-8m, it lights up, then I close the cover , it says processing, then it says the following...
Hi, please try reseating the print head.
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If issue still present call your printer manufacturer for service.
Tirzo
Jun 12, 2008 | Office Equipment & Supplies
Canon PIXMA iP4000 InkJet Photo Printer Logo
96 people viewed this question
old marine
old marine
