Alternator belt keeps breaking,merc c200,replaced twice, alternator also changed at second replacing,two weeks down theb line belt is torn again(wdc2030422r224229)
  • 3,799 Answers
Check the alignment of the belt wheels with a steel straight edge. and when you fit a new one ensure you have at least 1/2 inch play in the top run of the new belt. You are not supposed to be able to cut cheese with the belt, you have to allow for movement as the belt is moving quite quickly when working.
Posted on Apr 04, 2011
My car keep on breaks alternator belts and it also makes this loud whistling noise. I've put on a new water pump, 3 alternators and several alternator belts
make sure that the pulleys of all the driven equipment are in alignment and not at a bit of an angle to the axis of the drive belt
To break belts something is not lined up properly or something is not turning freely
Dec 31, 2015 | 2000 Mazda Protege
My mazda protege keeps breaking alternator belts. I've put on serval alternator belts, a new water pump pulley, and 3 alternators and my is still breaking belts
Replace belt tensioner, any other pullys, I worked on ? vehicle where the pully would spin but would stop every so often.
Merc c200
Normally you drivecaway in your second gear if it'scan auromatic gear unit, but bumpy is a vacuum tube which needs to becreplaced .
Aug 18, 2014 | Mercedes-Benz C-Class Cars & Trucks
1997 mercury villager alternator keeps going bad. Any reason for this?
Check the lines of the alternator sometimes it gets corrosives
Check the tension on the drive belt, bearings, brushes...
Take the current alternator and test it with the new one and check the voltage in the store where you purchased.
check for shorts.
check that gets enough ground.
Also, just because its new does not mean its good special if it's refurbished that I don't know where you purchase it.
I remember a time that I replaced my refurbish steering power pump 6 times. pump was defected took me 6 times. it could be the Alternator regulator to be faulty.
how you can tell if your alternator is faulty. the lights on inside your car will blink go off, when you change station on your radio go off and on, dim, fuses blowing, head lights bulb blowing... check it out.
Test the alternator both the one you have now and a new one,
get second opinion to another place.
If is refurbished and keeps dying try to get the genuine for your car.
Good luck
Dec 20, 2013 | 2001 Mercury Villager
The Battery on my 1998 Buick Riviera keeps running down..I have replaced the battery twice but the problem is still there.I had an Auto electric expert check it out and he repaired the Fuse panel which...
Any Auto Electrician would be able to trace the leak and advise accordingly. Maybe the alternator is not charging properly, is the fan belt loose etc etc
Jun 13, 2017 | 1998 Buick Riviera
How often should you change transmisson fluid&filter
Every 3 years & not more than 30,000 miles
on all vehicles. Power Steering also
Yours only will drain 3.5 to 4 quarts
You will have to do it 4 times.
Twice, then drive a couple weeks
No problems two more changes
with filter replacment on second round
Mercon V --in trans
Dex Merc- in steering
Coolant -Yellow GO5 every 3 years
Brake Fluid - every 2 years on ALL Vehicles
Feb 01, 2011 | 2005 Lincoln LS
I can't stop the squeak on my 8.1l chevy 2500hd.
There is a pulley out of alignment. Only 1/8th inch out will cause a serpentine to sqeak.
Mar 01, 2010 | 2001 Chevrolet Silverado
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
