Question about Sony Playstation 3 (PS3) Console
Have had a PS3 for about 18 months and ran on an older style tv without a problem. I recently bought an lcd tv and a HDMI cable, since connecting the PS3 has had intimitant operation, it runs for a while then the blue screenof death appears and now just the blue screen with no signal on the tv screen. is it the PS3 , the tv or the cable that is likely to be the cause?
  • chalkster64 Apr 04, 2011
    thank you, unit appears to be working okay now. and my teenage son almost hugged me.
  • 3,530 Answers
Welcome to Fixya
Try to perform video reset since you are using new TV with your PS3.
How to do a Video Reset: With the PS3 in stand by mode (red light on front of the PS3), hold the power button down until you hear two beeps (about 5 seconds). The PS3 will turn on and automatically reset giving you the best settings for the type of TV and cable being used.
Always do a Video Reset when you change TVs and/or cables to get the best settings for the PS3.
Thank you for using Fixya!
Posted on Apr 04, 2011
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I'd like to connect my toshiba satellite L655 to my tv, but I don't know how. any ideas?
If you have a flat panel TV (LCD or Plasma) then you can connect your laptop using an HDMI cable. Your laptop should have an HDMI port on the side. Buy the cheapest HDMI cable that is long enough (six feet ought to do it). Don't pay more for a "gold" cable, it's a rip-off. With HDMI, video and audio are carried in the same cable. Your laptop should automatically sense the TV set and auto-adjust itself.
If you have an older-style CRT TV then things will get more difficult. Then you'll need a VGA to composite or VGA to S-video. With a converter, you need separate cables for video and audio. Here's one that will work:
http://www.chronos.com.tw/_products_0616/tv/PC%20to%20TV/Pc%20to%20Tv.htm
Using the converter, you'll have to tell your laptop that you are connecting to an external device.
Oct 12, 2010 | Toshiba Computers & Internet
No HDMi signal
I ran across this problem before. Turned out being a bad HDMI cable. The was one prong in the cable bent and caused the problem. Try a different cable first. Sometimes it is the simplest things that cause the problems.
Jan 08, 2010 | iLO 3200 32 in. LCD Television
Popping noise from speakers
You have a problem indeed. try lowering the tv volume . if the signal is too high on tv it can cause some problem with the sound system if that dosent work then you may have some electronic sound output resistor problem.
Aug 15, 2009 | Teac DC-D6300 CD Shelf System
LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Jul 15, 2009 | LG LHY-518 System
No sound on pc connection
HDMI outputs from devices such as DVD players do carry both video and audio, but the HDMI output from your computer video card only carries video. You'll need to connect a cable from the computer sound output to the TV as well.
Feb 25, 2009 | Sony KDL-26U2000 26 in. LCD Television
PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
