It is spinning but not pumping out water - Washing Machines
    Problem Solver:
  • 9 Answers
Drainage problems can be caused by:
a) Blocked Filter chamber
b) Blocked Sump
c) Blocked Drain Pipe
d) Failed Pump
You can check the sump and drain pipe are not blocked by disconnecting the drain pipe from the undersink trap or waste pipe and lowering to a bowl on the floor. The water should drain out into this bowl under gravity if there are no blockages. If this drains then you can should check the filter chamber if it is accessible on your washing machine (not all are). I would recommend you unplug the machine or take the fuse out of the switched socket before doing this. Drain the drum as above before doing this or you will get a gush of water coming out. You will usually have to remove a cover from the bottom of your machine to get to the filter chamber and twist it ant-clockwise to unscrew it. Check for any coins buttons etc trapped in there. If there is nothing there check the impeller will turn relatively easily by hand. If you still can't find the problem you might have a faield pump and I would recommend contacting an engineer.
Posted on Apr 04, 2011
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Does not complete spin cycle
Ok, when this happens, its usually because of a drainage issue. the spin cycle has to work in conjunction with the drain pump to remove the water during the spin cycle and, if there is a clog or drainage issue, the spin cycle will shutdown. check the following to address this drainage issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Frigidaire Washing Machines
Washer won't spin out the water
This is a drainage issue. the spin cycle works in conjunction with the draining pump. they both work at the same time during the spin. if the drainage hoses or pump are clogged with debris, it will prevent the water from being drained properly.
Check the following to address the faulty drainage issue.
2. Water Pump
May 31, 2009 | Maytag Washing Machines
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Doesn't spin all the water out
sounds like the coupler that connects the motor to the transmission is going bad.  A $20 part
Mar 30, 2009 | Kenmore 24902 Top Load Washer
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Gibson front load washing machine will not spin
are you sure the pump is plugged up and was the impeller damaged
Mar 29, 2008 | Washing Machines
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
