Non-functioning keys toshiba equium keyboard m40x 149
My keyboard is acting up. my o,i,u and _ keys work intermittently. Is my keyboard dying, do I have a virus, is there anything i can do?
  • sara_tindall Aug 05, 2008
    I'll try your advice re the regular desktop keyboard, thank you very much
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Have you tried connecting a regular desktop keyboard to your laptop? If so, does the same thing happen?
Keyboards do develop problems, and can usually be fixed by replacing the keyboard. It's not necessarily a virus (actually highly unlikely).
Posted on Aug 05, 2008
  • Coss Aug 05, 2008
    Very good.
    I would contact toshiba about obtaining a replacement keyboard for your laptop.
    Changing them is fairly simple.
    Pop out the old keyboard, disconnect the connector (one ribbon cable) take the new one, connect the cable, pop the keyboard back in place.
    You can try here to see if they have one to work for your laptop
    http://laptopparts.vivotechnology.net/It...
Hey i have a Toshiba Equium M40X-148 and the screen wont turn on. When i power the laptop up the power light lights up but the screen stays blank. Any ideas on what the problem maybe
If you tilt it to the light, do you see a faint image?
Can you connect the laptop to a external monitor and toggle the FN + F5 key to adjust monitor settings to output to the 2nd screen.
Feb 10, 2011 | Toshiba Computers & Internet
Toshiba Equium 2000 does not recognise USB keyboard
check bios settings and enable kboard usb settings is ok, save to cmos and reboot
Feb 18, 2010 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Shift key locked Toshiba Equium keyboard
Go to control panel, accessibility options, disable Sticky Keys, and such on the general tab
Jan 08, 2010 | Computers & Internet
Where is the memory card for Toshiba Equium M40x-149 model
The memory modules are under a screwed panel on the bottom of the laptop.
Click on this link for a picture of this memory slot.
http://img185.imageshack.us/my.php?image=ramshotzs5.jpg
Jul 30, 2009 | Toshiba Computers & Internet
How to remove keyboard of how to remove the cover of a toshiba equium m40x 148 laptop
try this link
http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
good luck !
Jul 02, 2009 | Computers & Internet
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
@ KEY NOT WORKING
if one key on the keyboard no longer functions, try an external keyboard. It the external keyboard works normally, replace the built in one
Jan 18, 2009 | Toshiba Satellite A100-S8111TD Notebook
Equium M40X gets overheated
this is a laptop computer?
THis is probably a simple heating problem. if it is, you'll have to replace or otherwise repair the heatsink, and maybe the CPU as well.
In general, if this is still under warranty, your best bet is probably to just return it to toshiba for repair/replacement.
I would NOT reccomend opening the case on an in-warranty laptop.
However, in case this ISN'T a heating problem, or if you need a temporary workaround... these ideas MIGHT work. they won't be permanent solutions, though.
1. try setting your bios, and your windows settings, to the options that use the least power.  less power = less heat.
2. If you deliberatly overclocked your cpu at some point, reset it to normal speed. or even less-then-normal speed.
3.  are you certain this isn't just a power problem, or a corrupt operating system?  you might want to try reinstalling the os, and running the computer from an AC outlet, maybe even with the battery removed
Mar 29, 2008 | Computers & Internet
Equium M40X freezes
Hi, it seems your experiencing a overheat issue. At least one fan inside your PC has stopped working. The PC monitors internal heat, when the PC reaches a certain temperature it will shut down & or freeze. Chances are it's the CPU fan.
Link for your model no#
http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/jsp/SUPPORTSECTION/discontinuedProductPage.do?service=UK&DISC_MODEL=0&highlightOption=5420&com.broadvision.session.new=Yes&PRODUCT_ID=104113
Mike
Toshiba Equium M70 Trouble with keyboard only two keys dont work with the shift key
The first thing I would try is buy a can of compressed air and give your keyboard a good cleaning. There may be stuff under the keys that are letting them work. Was there any liquid spilled on the keyboard?
Nov 02, 2007 | Toshiba Equium 100 PC Desktop
Computers & Internet Logo
620 people viewed this question
David Payne
David Payne
