Intermient fault. The set comes on and goes off . Tried few capacitors and dried joing but no joy. can u plz help me? Thanks
  • 3 more comments
  • 1stopman Apr 04, 2011
    Hi
    I have checked all capacitors and replced even lower valued ones.
    Also checked ceramic ones but all ok.
    No burnt parts + no smell or carbon anywhere.
    Chcked all loose/dry joints.
    What else can be?
    This was not what i expected.
    Can any one else help me here plz?
    thanks
    lg22ls4r tv/monitor
    intermitent fault comes on and goes off
    changed some capacitors and checked the rest.
    soldered some dry joints.
    and stuck as the fdault still there
    thanks
    HI
    LG 22ls4r tv/monitor
    Intermitent fault comes on and goes off
    Checked replaced capacitotrs plus soldered all dry joints
    The fault still there.
    Can u plz help.
    thanks
    Can u Help me ?
    I have lg22ls4r tv/monitor with intermitent fault.
    Set comes on and goes off
    I have checked/replaced capacitors in power supply and soldered few dry joints.
  • 325 Answers
You need to check the OUTPUTS of the power supply after the cap replacements. If those are reading out ok...then check the BN_on 5v line going to the backlight inverter. After that check the 3.5v or 5v going to the mainboard. You have a fault some where on a major component or it woudn't be turning off on you. Also, try UN-plugging the backlight inverter. If you hear sound and the tv says on...you need a new inverter!
Thanks. Let me know how it goes! please rate!!!!!!!
Posted on Apr 04, 2011
  • Andrew P.
    Andrew P. Apr 05, 2011
    As experts we need specifics of what you have tried. Also, we need specifics of the testing you have done AFTER the repair. We can't possibly know what you have and have not tried until you get specific examples of what you have done. Just saying, "tried caps and joints" won't get us anywhere. Primary of secondary on the powersupply? What value caps, on what line (24v? 12v?)? You can only get as good of an answer based off the question supplied and details supplied. "Not what I expected" is from the lack of imformation you are providing.
    Top Expert:
  • Televison & ... Master
  • 73,635 Answers
Hello
What is the brand name and model number of your TV? Will you please give me some more details of the faut that occured first, and what have you done to retify it; it will help me a lot to detect the problem I thinks. Ok.
  • The Knight
    The Knight Apr 04, 2011
    Hello
    Just check the supply voltage in its video section. Just give me details about what did you done in it, and to which section you have replaced the capacitors. Without knowing about your doings, how can I post a solution to your problem?
    President:
  • 2,187 Answers
Normally faulty capacitors are the culprit for this issue. Make sure all bulging or leaking capacitors are replaced. Check also for loose connections or burned parts or parts that have a burned smell while the power is not connected. It could also be a software issue, your sleep timer may not be working but this can be rare. You may want to play with this to test.
It may be the power supply circuit itself that needs replacing. Other parts when faulty may still allow the TV to run. Faulty parts that would let the entire unit over heat or burn out would trigger the shut down.
  • Nicolo Carlo Parazo Apr 04, 2011
    The fault may be with the power supply circuit. This is the first circuit that is internally connected to the power cable. This converts regular house voltage of 220v/110v to a usable volt by the rest of the circuit like 12v, 5v, etc. This is most especially true when the issue coincides with loss of voltage going out of the circuit.
    Other reasons is that flat panel CRT TVs shut down because 'X-ray' circuit detected high voltage on the x ray line. This is caused by faulty power supply (as mentioned above) or bad CRT which is leaking transparent oil. The circuits surrounding the CRT connected to each other may be faulty which may have been damaged by the voltage issue in the first place. The said reasons are more complicated and is expensive to replace.
My white knight turns on but dosnt spin but belt is ok can u help plz tried reset button but nothing happens
This will likely be the capacitor to the motor. A cheap & common fault to fix. With the door open and the timer set spin the drum by hand and close the door the cycle shouldvstart and your drum will then turn. Sure sign your capacitors blown.
Nov 01, 2014 | Dryers
LCD FAULT
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 28, 2014 | Televison & Video
Flashing red on light then goes to blue ,but does not come on
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 15, 2014 | LG 37LP1D 37 in. LCD Television
Help ive got a hitachi plasma tv i need a capacitor for
try the guys over at www.tvrepairworld.com just send them a email and they respond quickly they should have that capacitor.
Nov 07, 2012 | Hitachi 42 in. Plasma TV
Gateway p42m403 comes on for 30 mins then goes off will not come back on Found 5 100v 2200uf caps some buging on top .Is this a common fault
Yes that is main cause of the fault, because bulging capacitor is producing a low and unfiltered dc output that causes your unit malfunction, this bad capacitor is producing current but not enough to power up your unit sometimes you will hear some clicking noise that is the relay.
ekcnoel_46.jpg This is bulging capacitor and already leaky but common leaky capacitor starts at the bottom if you notice some wet mark under or at the bottom of the capacitor replace them, and also observe the solder part of the PCB because when this capacitor leak sometimes the electrolite gasses damage the solder part of the PCB to remove this electrolite gasses in the PCB you should use a laquer thinner and use a toothbrush to clean the affected part and let dry before resoldering the dry joints.
This is a sample of coldsolder, hope this help good day and bet regards.
Sep 24, 2011 | Sanyo Televison & Video
Tv will ot come on
This kind of symptoms is cause by faulty(leaky/dried) electrolytic capacitor in the power supply section. In the first stage of symptoms warm up will make itself stable and the unit will power up after a few attempt of plugging and unplugging from the outlet but it will get worst, time will come that the unit will not power up at all.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can be easily identify like in the sample picture below.
Leaky capacitor with dome at the top.
Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition, if not available you should replace all electrolytic capacitor in the power supply section. It will not cost you much because it is one of the cheapest parts on that board.
Click this LINK for more information regarding electrolytic capacitor.
Jul 30, 2011 | Televison & Video
Tv takes a long tome to come on
Good day!!!!
Jul 30, 2011 | LG 50PG20 50 in. Plasma HDTV
When I got this it worked now when i press the power button the power light comes on dim and goes out right away. I have tried changing the batteries and no joy. Any help would be great.
Hi, Quit a few of these NV monoculars don't have auto shut offs. So the switch on you NV unit is a momentary switch--that is as long as you push on the switch the unit will stay on. Once released the on/off switch, image will start fading because the capacitors are discharging there current to a point where image in the tube has clasped. stewbison
Feb 15, 2011 | Night Owl Optics Discovery™ NODS3...
Problems starting up
This fault is caused with hibernation settings.
Turn it off in control panel, power options.
Problem will be gone then.
All computers struggle to come out of Hibernation.
Regards
Richard
Apr 22, 2009 | Compaq Presario F572US Notebook PC
Folder lock software
go to sharejar.com
& download file explorer
Dec 19, 2008 | Nokia 3110 Cellular Phone
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
