Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson stylus cx 32000 error scanner read documents or contact service personnel how to rectify
SOURCE: epson CX3200 printer error
i just fixed the problem .. you have to reset the protection counter FIRST .. then do the reset using the triangle and colour buttons.. this it the link for the SSC utiliity to reset the counter www.ssclg.com/epsone.shtml .. my printer works fine again
Posted on Mar 07, 2008
  • 110 Answers
SOURCE: scanner error see your docmentation and call service if necessary
Please follow the steps below to resolve your issue.
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4) Turn on the printer, and the error should be cleared.
Posted on Aug 22, 2008
chazman05
  • 48 Answers
SOURCE: I NEED MANUAL FOR REPAIR EPSON STYLUS CX-3900
http://tech.epson.com.au/downloads/message.asp?platform=winxp&techtips=techtips&EmailAdd=&MetricIDReturned=2694589&submit=Search+%3E%3E&sCategory=Multi_Functional&id=styluscx3900
Copy and paste link in browser then download the user manual.
Posted on Dec 16, 2008
SOURCE: My computer does not recognize my scanner
YOUR TECHNICIAN WOLKED ME THROUGH A SOLUTION THAT FIXED THE PROBLEM TEMPORARILY.  (REINSTALLING THE ORIGINAL SOFTWARE)  I WAS ABLE TO SCAN 1 IMMAGE, BUT COULD NOT SCAN ANOTHER.
Posted on Feb 20, 2009
tigertail
  • 163 Answers
SOURCE: service manual for epson stylus dx4000 series
You could try here:
http://www.2manuals.com/product_reviews_info.php?products_id=792&reviews_id=150
Posted on Mar 16, 2009
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
E-90 error message on Epson CX6000
If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the Stylus CX.
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the Stylus CX back on.
Also
If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  5. Close the scanner.
  6. Turn the Stylus CX back on.
Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus CX3200 Error
Possible scanner failure.
Turn off your printer. Disconnect it from your computer. Toggle the transportation lock on the scanner unit if there is any. It has to be in the unlock position. Turn the printer back on.
If your unit is not yet a year old, please contact epson for your warranty options.
To help you find an epson certified servicer near to your area, please log on to epson.com.
Apr 28, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson CX 3200 - twain error scanner not recognized
Click HERE for a troubleshooting guide
Click HERE for drivers and documentation
May 26, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epsonrx 425
Turn the Epson Stylus CX off and then back on. If the error does not clear, contact your local authorized servicer or contact
Apr 07, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
