Question about Home
Bremen simplifit lever tap has come loose how do I tighten it up
3 Suggested Answers
  • 49 Answers
SOURCE: My lever is loose. How do I tighten it?
take a flat head screwdriver and puch the spring loaded pin near the plate in and pull the lever off... use the screwdriver to pry the finish plate off, then tighten the 2 bolts you just exposed... reverse it to get lever back on...
Posted on Sep 09, 2009
  • 10865 Answers
SOURCE: TAP IS LOOSE AND I AM UNABLE TO TIGHTEN
The tap is held in place with a large nut. There is a special wrench with an adjustable handle called a faucet wrench, available at home depot and other hardware stores which will enable you to tighten the faucet with ease. J.
Posted on May 25, 2010
A LOOSE BATHROOM SINK HOT WATER HANDLE
Is it the whole tap or just the knob/lever?
Whole tap, there is a nut underneath that needs tightening. Don't over tighten it.
Just the knob or lever that you turn to turn on and off? You will find a small screw at the rear. It is a set screw, so it doesn't have a head, it just sits in a hole. Usually a hex key to tighten it. The hole is often filled with gunk so clean it first with an old toothbrush. The set screw is often sticky so undo it I turn before you tighten, lift the knob off, screw the screw in until you see it coming out of the inside to clean the threads. Unscrew the screw back out, replace the knob and tighten it.
Oct 10, 2015 | Plumbing
The three point hitch up down lever moves as tractor is moving, handle/lever very loose.how can i tighten it up?,
I'd try to get a repair manual. MFG customer service may also be helpful, email or call.
manualslib.com may have it. There may be a locking nut that has come loose, and therefore the nut that holds it tight has also come loose. Follow the lever to where it attaches at a pivot point. Look for loose and nut to tighten.
Mar 18, 2015 | Garden
Loose take up lever
you can try tightening it up yourself or take it to a sewing machine repair shop and let them tighten up the take up lever and see if there is anything wrong with the lever and why it's loose.
Sep 09, 2013 | Sewing Machines
Loose lever how to tighten
What type of lever is loose? Is this a brake lever, shifter lever, or quick-release lever? I may be able to help; but there are different solutions to each of these. If you're not certain; perhaps provide a picture and I can certainly give it a try.
Matt @ roadragecycling.com
Oct 15, 2012 | Cycling
Gear shift loose. How can I tighten so that this will stop coming loose? I tighten & tighten until I break the bolt.. Any advice?
You could buy a new gear lever, if the shaft is in good condition, or you could widen the gap in the gear lever by cutting it with a hacksaw untill you have removed aprox 5mm thus allowing you to clamp up the lever, tighter on the shaft
Apr 14, 2011 | 1973 Honda CB 350 F0
May 25, 2010 | Plumbing
My moen single lever faucet is loose, how do I tighten it?
On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
Nov 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Sep 07, 2009 | Kwikset Locks & Locksmithing
MY HARLEY ULTRA CLASSIC "1999 " SHIFTER SEEMS TOO LOOSE. WHAT SHOULD I DO?
Follow the shifter linkage back from the forward controls to the shift lever going into the transmission. Make sure the joints and bolts in the linkage are tight. My guess is the shift lever is loose on the shaft. If so, there is an allen head bolt that secures the shift lever to the shifter shaft. The shift lever is split and the allen head bolt is a pinch bolt. It's kinda hard to get to, but an allen head socket, short extension, and a rachet will work. Make sure this bolt is tight. Use a little penetrating oil before trying to tighten it. If it won't tighten, try taking the bolt out, chase the threads in the shift lever with a tap, and replace the bolt with a new one.
Jul 12, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Mini wide spread vanity tap handles ( mostly left ) are loose.
if there is a cap on top, remove with a sharp object(razor knife) and tighten phillips head screw Just guessing but this is a common setup
Jan 14, 2009 | Moen T4945/9300 Castelby Two Handle Mini...
Home Logo
63 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
