Question about Panasonic MonitorCRT, Color 20", 500 TVL, OPEN BOX
Manually changing channels on Panasonic TC-21PM10K caused unit to go into child lock mode. What's your suggestion to restore unit back to initial form.
Try hitting the channel up and down keys at the same time. maybe its a matter of button mashing.
Posted on Apr 04, 2011
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
How to unlock the child lock for panasonic tv tc 20lchow to unlock the child lock for a panasonic tv model tc 20lc
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 02, 2015 | Panasonic TC-20LA2 20-Inch Flat Panel LCD...
Hi the child has put a lock on my tv and now I cant manually change channels or volume how do I manually take lock of thomson tv
You'll probably need to use the remote control to access the TV's settings menu to deactivate the child lock feature.
Oct 15, 2014 | Televison & Video
How to unlock child lock for Panasonic Television model TC-21Z88K?
Hello
Just try this method. Most of the Panasonic sets will respond to this procedure.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
OK.
Mar 02, 2011 | Televison & Video
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
Mistakely locked my TV(4 system CATV HYPER-BAND TC-2101T)
my TV locked, but the password had not been activated. what can i do
Aug 19, 2009 | Panasonic TC-14KM30R 14" TV
CHILD LOCK STUCK ON
I agree with the initial solution, depress the child lock button for at least 3 seconds.
If it does not clear, then try again.
Good luck.
Please rate my solution.
Thanks.
Feb 12, 2009 | Hotpoint WMA74 Front Load Washer
Channel changes automatically
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Child Lock Aiko TV
I had the same problem with an AIKO TV. The childlock was on and initially I couldn't find the remote after moving. Unfortunately the only way I got it unlocked was with the remote. So I turned the TV off with the remote. Then turned it back on and then had to go into MENU and change child lock from on to OFF. Sorry no other handy suggestions if you haven't got the remote.
Dec 08, 2007 | Haier HTF27R11 27" TV
Panasonic MonitorCRT, Color 20", 500 TVL, OPEN BOX Logo
85 people viewed this question
Top Panasonic Home Security Experts
Walter Dominguez
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Panasonic Home Security Expert? Answer questions, earn points and help others
