SOURCE: external hard disk driver
do you know from were i can get the ( X driver ) Program
cuz i got the same problem plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
SOURCE: External USB Hard Disk is 120GB is not dected in winxp pc.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk
into a new enclosure. WD Mybooks are SATA, but double check the hard disk
connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data
recovery facility with a 'clean room' , the cost is usually more than
$800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
the Hatachi 80 gig looks the same as the 120 gig verbatum 47558
also had the same blue flashing light and no recognition by XP
I open the case and removed the drive from the pc board. cleaned the contacts and reconected the PC board , the fault was oxidisation
SOURCE: when I connect my seagate expansion external hard
either an issue with the hard disk, or with your system. Make sure the hard disk has power on it and if you can, it would help to test it on another computer to confirm if it works. If you have ruled out the possibility that it is the hard disk, next is review if the hard disk has system requirements you need to meet. If the requirements are met by your XP SP2 machine, you may try updating the computer's system software/chipset drivers and a BIOS update may also be necessary.
SOURCE: my seagate external hard disk
test all leads that are attached to your external hard drive
good luck
