Hello! What is the maximum ram-size for Acer eMachines 250-01G16i? 2GB, 4GB or 8GB? There is only 1 memory-slot. Best regards, Bjorn Stenmark
    Scholar:
  • 72 Answers
Hello, The max RAM you can insert is 2GB here is the output from crucial.com
  • Chipset: Intel 945GSE
  • Drive Form Factor: 2.5"
  • Drive Interface: SATA
  • Maximum Memory: 2048MB (2GB)
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 1024MB removable
  • USB Support: 2.x Compliant
Hope this helps!
Posted on Apr 04, 2011
Testimonial: "Hello! This was very helpfull - and fast! Thanks a lot! I´ll recommend you to my friends!! Best regards, Bjorn Stenmark"
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
How to install ram memory on e644g-0663 laptop
http://support.gateway.com/us/en/emachines/notebook/2011/eMachines/eme/eme644g/eme644gnv.shtml
http://support.gateway.com/emachines/notebook/2011/eMachines/eme/eme644g/eme644gsp2.shtml
Up to 8GB of DDR3 Sdram ram memory that is SO-DIMM for laptops, and 1066MHz.
That is PC2-8500 that is SO-DIMM
An example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4505186&CatId=4153
There are TWO Ram Memory slots. EACH one has a maximum amount of 4GB.
Total Maximum Amount of Ram Memory is 8GB.
IF, just one Ram Memory module ('Stick'), is to be used, it is placed in ram memory Slot 1. (DIMM 1)
(The Processor reads what is in Slot 1 first. Cannot have ram memory in Slot 2, and not Slot 1 also )
What?
No that's okay Acer/Gateway/eMachines!
I have access to the SERVICE MANUAL, bahahahaha! Your lack of info doesn't bother us...........
http://www.manualowl.com/m/eMachines/E644G/Manual/258030
This is a PDF file. Scroll the page down using the scroll bar all the way to the right, until the top header of the PDF file reader shows.
To the immediate right of the number 216 at the top, is the Page Down Arrow.
To the left of the number 216 is the page number box.
The PDF reader page numbers do Not match the actual manual's pages.
Put your mouse cursor in the page number box.
Backspace the 1 out.
Left-click once.
Type -> 95
Press the Enter key on your keyboard.
(In the Top header is also the controls for view size.
To the left of the page number box is a Slider that is a blue 'Dot'.
Left-click on the blue 'Dot', hold the left mouse button down, and drag it to the left to Decrease the view size.
To the right to Increase view size )
Under the bold subheading - Prerequisite, click on the blue -
Base Door removal
Bottom of laptop facing you, open Battery Compartment to the Top, away from you, the Base Door is at the bottom.
Rectangular cover that has two Philips screws holding it on.
One screw at the Top/Middle, one screw at the Bottom/Middle.
Remove these two screws, do not lose them. (Double-sided sticky tape to table, and stick the screws to the tape )
BEFORE beginning;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
To go on;
This is a general example of a laptop SO-DIMM ram memory module,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Note the Locating Notch on the bottom, and the two Side Notches on either side.
The Locating Notch at the bottom, lines up with a Locating Lug in the bottom of the ram memory slot.
For this reason it can ONLY be installed in one direction.
There are spring clips that 'snap' into the Side Notch/es.
The top of one spring clip is eased to the outside of the laptop.
Now ease the other spring clip to the outside.
Once both spring clips are freed from the Side Notches, the ram memory module should pop up a little.
(Sometimes you have to keep one spring clip, held out with one hand, and with the other hand move the other spring clip out )
Remove the Ram Memory module, at almost the SAME angle as it is now. Slightly tilted.
DO NOT bring the Ram Memory module straight up, or you will damage the gold plated contact pins of the Ram Memory module, and also the contact pins down in the ram memory slot.
Notice how ram memory in Slot 1, (Slot A), is on top of the ram memory module in Slot 2. (Slot B)
If you have two ram memory modules installed, you have to remove the top ram memory module, first. (Slot A)
Again, if you are just going to use ONE ram memory module, it goes in Slot 1 (Slot A)
Look at the ram memory slot, and the Locating Lug in the bottom, and/or observe which way the Locating Notch on the ram memory module was, before you took it out.
Line the ram memory module up with the Locating Lug.
Install it at the same angle roughly, that you took it out at.
Once in the correct position the spring clips 'bumps', will snap down into the Side Notches, of the ram memory module.
(Click / Click)
Reinstall the Base Door.
Reinstall the Battery.
Attach the AC adapter (Charger), and plug the AC adapter into power.
(ALWAYS plug into the laptop FIRST, then plug into power. Otherwise a power surge could happen, and burn out electronic components in the power section of the motherboard)
WAIT 1 minute, turn the laptop on. BIOS will recognize the ram memory. You're done.
http://videos.howstuffworks.com/howstuffworks/49-how-to-add-ram-to-a-laptop-video.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 22, 2012 | eMachines Computers & Internet
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
I have a HP dc7600 small form pentium4HT 3.4 GHZ with 1GB of Ram. What type of RAM do i need to max this machine out safely?
Memory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 4GB
Slots: 4
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
icon_note.gifAlthough the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.When using PC2-5300 parts the maximum memory is 2GB. When using PC2-4200 the maximum is 4GB.
Jul 30, 2011 | HP dc7600 Small Form Factor P4 640...
I have a HP 7600dc Small Form pentium4HT 3.4 GHZ. it has 1GB of Ram with 4 slots whats the best, safest way to max out the RAM in this machine? What type of RAM do i need?
Maximum Memory: 4GB
Slots: 4
Jul 30, 2011 | HP SMART BUY 7600USDT (N094UA) PC Desktop
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
Can I upgrade the ram on the acer aspire 5630 notebook?
Yes, you can.
You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Nov 25, 2010 | Acer Aspire 5630 Notebook
If i change the ram stick will my pc reconise it
Yes.
Provided,
1) It is no more than the maximum amount, for that ram memory slot.
2) Adding it, will not go over the Maximum Total Amount for the motherboard.
If this pertains to an Acer Aspire T135 desktop computer,
A) The Maximum Total Amount is 2GB.
B) The Maximum Amount for Each ram memory slot is 1GB.
C) PC3200 is the best you can use.
DDR Sdram at 400MegaHertz. (400MHz)
[It can also use PC2100, and PC2700.
DDR Sdram at 266MHz, and DDR Sdram at 333MHz, respectively ]
Once you install the ram memory, BIOS should automatically find it.
If you are only going to use one ram memory module, be sure to put it in Slot 1.
The Processor reads ram memory in Slot 1 first.
[Slot 1 is closest to the Processor.
It may have DIMM 1 printed on the motherboard, next to Slot 1 ]
Jun 21, 2010 | Acer Aspire T135 PC Desktop
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
