Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag SidebySide model MZD2766GES Fridge portion not working...
There has been an intermittent clicking/buzzing noise in the top portion of the refriderator that lasted for a month. Finally the refridgerator is no longer cold, but the freezer seems to work fine. There was some frost on the back panel I removed, but nothing heavy. After reading some fixya forum posts, I think I need a new Adaptive Defrost Board and a new Defrost Heater Sensor. Can you please tell me where to find the Defrost Heater sensor on my unit and the appropriate part number?
Also, please tell me if you feel I am replacing the wrong parts. Thanks.
Marty
    Champion:
  • 210 Answers
Yes probably the a.d.c. but make sure all ice is defrosted from evap. coil. remove the freezer panel and use heat gun or hair dryer.
Posted on Aug 07, 2008
How do i fix my fridge that stopped working?
To aid in troubleshooting, the link below may be of help:
MAYTAG MAYTAG REFRIGERATION Parts Model MZD2766GES Sears PartsDirect
You may have a failed defrost heater.
Jun 27, 2015 | Maytag MZD2766GES Side by Side...
MZD2766GES compressor not firing
Is your compressor giving sounds like a buzz followed by a click periodically? Is the compressor exterior warm/hot? Most likely the compressor start relay assembly is bad, or the compressor is locked up, (frozen internally). If you connect an amp probe to the red wire of the compressor, and the momentary reading meets or exceeds the LRA rating on the compressor tag, most likely the compressor is at fault. Pleazer Appliance...
Apr 09, 2014 | Maytag MZD2766GES Side by Side...
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
I have a side by side maytag fridge model number MSD2655HES it is about 6 years old. It seems to be cooling fine but makes an intermittent buzzing noise followed by a click what could this be?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 29, 2011 | Maytag MSD2655HES Side by Side...
Maytag MSD2351HEB sidebyside occasionaly goe thru frequent cycling buzz. Last for a couple of seconds, then repeats a few minutes later. sounds like a solenoid click when going off.
if this model has the techumse compressor it is probably drawing high amperage and kicking out. the click and buzz is the compressor winding stressing to draw the energy needed. compressor maybe bad. the compressor model usually starts with a t11...
Aug 01, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
MZD2766 fridge light works but the fridge and freezer is not working. The water dispenser and ice cube not working either. I did hear buzzing coming from inside the top fridge side occassionally.
it could be a defective cold control,you can use a jumper wire to bypass this and see if the compressor starts,or it could be a bad ptc overload on the compressor itself,and these are easily changed too
May 23, 2010 | Maytag MZD2766GES Side by Side...
5 yr old Maytag fridge stops working
solve dvb skystr 2TV//MAC:00-08-c9-A2-32-9F/satllit Eutelstw3 7E
Dec 05, 2009 | Maytag Refrigerators
Noise in upper right (roof) of Frige
Replace the Maytag 61005988 Adaptive Defrost Timer Assembly. It controls the defrosting od the coils. See below what happens when it goes out.
Mar 14, 2007 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
213 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
