Question about LG KU990 Viewty
12hours battery life..is that maximum life battery of my phone?
    Sergeant:
    Champion:
  • 207 Answers
Yes, maximum. You won't see this type of battery life if you use it throughout your day.
Posted on Apr 04, 2011
The battery drains off very quickly as soon as i fully charge it and unplug it,, it hardly satys upto 12hours with minimal phone usage,, the battery metre usage shows cell standby 42% and also phone idle...
Go to teh phone settings, and under sync accounts disable all teh sync accounts that you are not using such as stocks etc. These constantly use up data and hence drains your battery as they do so in teh background. This should greatly improve your battery. If not, your battery must eb damaged and i woudl suggest you purchase an extended battery which may have up to 40% more battery life.
Jan 12, 2011 | HTC Wildfire Cell Phone
Tip
How to increase processor speed of a rooted android phone
For most smartphones, the processors are clocked at speeds much lesser than their maximum supported speeds to improve battery life. That also means you are not enjoying all the juice your phone can give you.
Lets see how you can overclock your android phone to unleash its full potential.
Important: Overclocking requires super user permissions and so your phone needs to be rooted.
SetCpu is the best app out there to overclock your android phone. Its sheer simplicity and useful options sets its apart from its competitors. You can either download it as a paid app from the Android market or simply download the zipped apk from XDA forums.
Using SetCpu. Once you install and start SetCpu, it will first show you a screen with two options. Unless you have a specific reason to do otherwise, simply select "Autodetect Speeds Recommended".
A screen will come up where you can change the maximum and minimum clock speeds and select the scaling method. SetCpu will automatically detect the maximum clock speed your processor supports.
Max - maximum clock speed.
Now its a bad idea to rush and drag the slider to its maximum in one shot. Although there will be no problems for most phones, it could lead to instability for some. Instead, try increasing the clock speed in small steps, running some heavy apps like games and if you don't see any instability, go back and repeat with increasing the clock speed. In case you find your phone going unstable at any speed, just set the speed to slightly below that value.
Min - Minimum clock speed.
Minimum frequency is the speed at which your phone will run when it is idle or no heavy apps are running. Setting it to a too low value can cause your phone to go slow with incoming calls, alarms and any other app that runs while idle. Generally it is advisable to set it to at least one third of the maximum speed your phone processor supports.
Scaling.
The scaling option determines how aggressively the minimum and maximum clock speeds will be applied. The drop down menu gives 5 options as below -
  1. OnDemand - Automatically sets the minimum and maximum based on load. This is the recommended setting.
  2. Conservative - Very similar to OnDemad except that the scaling is less rapid.
  3. Powersaver - Makes your phone run at min speed always to give maximum battery life.
  4. Performance - Makes your phone run at max speed always.
  5. Userspace - This option is useless as of now and is kept as a future option for apps to change clock speed that SetCpu doesn't use.
Once your phone looks comfortable with the new frequencies, you can use the "Set on Boot" option to enable the settings permanently.
Tutorial Video:Overclock Your Android Phone to Unleash its Full Power
Download link: http://forum.xda-developers.com/attachment.php?attachmentid=648354&d=1310073004
on May 27, 2015 | Android Apps
Tip
How to make your phone`s battery life longer!
Never leave your phone charging full nights (exception if the battery is new and needs formating). Sometimes, a lot of Nokia cell phones don`t show up the "battery full" message. This is not to worry, just leave your phone to charge maximum 3 hours.
Check your settings! Some phones have LED`s and other lights working with no particular/good use (for example: if you phone has music lights, if you disable those, your battery will have a longer life). Disable key stroke tones, you are looking at the screen when you are typing, so you don't need a beep every time you press a key, this is a really good battery saver! If you listen to music, use how often you can headphones/handsfree, this saves your battery and protects the phone`s sound parts to get broken.
on Dec 14, 2009 | Cell Phones
LG VU,battery indicator shows fully charged but I can only talk a couple of minutes before phone shuts off and shows dead battery? Just a dead battery or something else going on here?
I believe the cells of your battery is very weak that is why it can no longer hold charges for long.
All you need to do is to get a new battery on your phone and makesure you charge the new battery to its maximum capacity before you start making use of it.
This will help preserve the life span of the battery and make it last longer.
Take care.
May 02, 2010 | LG Vu CU920 Cellular Phone
Drop my samsung g600 in cup tea last nite not working
1st thing to do take battery out to stop power do you no how to take phone apart? if no there is a website that shows you cause dry it with a cloth then go over it with a toothbrush and leave for 12hours and see what happens then
Jan 20, 2010 | Samsung SGH-G600 Cellular Phone
Battery life only last one full day on normal usage n web surfing and music and video
The battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and the maximum battery capacity reduces with age and use.
You need to purchase a new battery.
Nov 25, 2009 | Nokia E63 Cell Phone
I was to advised to charge a new battery only 2 to
Two to three hours should fully charge your battery, to porlong battery life I would let the battery run as low as possible before recharging. Recharging half charged batteries causes the battery to age faster.
Oct 27, 2009 | Cell Phones
Battery charge question
in this phone when the battery is fully charged the running battery indicators stop at full position. U must charge every phones battery a maximum of 2 hours b'coz charging more than it reduces battery life and if the battery is not fully charged in 2 hours u must charge it after 20 minutes again
May 20, 2008 | Nokia 2610 Cellular Phone
LG KU990 Viewty Logo
44 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
