Question about Canon CanoScan LiDE 90 Flatbed Scanner
I have a problem with cannon lide 90 scanner like following Error reads: cannot communicate with scanner. Cable maybe disconnected ( I have checked that not disconnected). Scanner driver will be closed. some of computers are ok and some of computers aren't ok. so,what can do for this problem. if you are ok please help me Thank you, Joe
My canon lide 90 "the scan slider" thing get stuck and can't finishing scanning. I would like to open it up and fix it. Do you know how or any tutorial that could take me step by step? Thank you Adriana
Posted on Apr 07, 2013
  • cereja_foryo Apr 07, 2013
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I have many years reapairing Canon scanners and I think I can help you out.
This is a very common problem with Canon scanners even the larger commercial scanners. To correct the problem you just need to reboot your computer. What happens is the memory gets full of bits and pieces of images and needs a reboot to clean out the memory. Also another thing that can cause this problem is if your computer goes into sleep mode, you will then loose the connection to you scanner also. My suggestion is when your done scanning for the day shut your computer down if you cant then at the beginning of the day just do a reboot (restart) and you will be good for the day.
I hope this helps you out if it does please leave me some positive feedback.
Posted on Apr 04, 2011
I installed the new Canon LiDE 110 scanner drivers. When I click on the Scan button, it gives the error msg: Cannot Communicate with scanner. Cable may be disconnected. Scanner driver will be closed
I was getting that same error message, every second time I tried to scan something. I had the scanner connected to a USB 3.0 jack. I switched to USB 2.0 jack, and the problem was solved.
Oct 06, 2012 | Canon CanoScan LiDE100 Flatbed Scanner
Error reads: cannot communicate with scanner. Cable maybe disconnected ( I have checked that not disconnected). Scanner driver will be closed. What must I do
reinstall the scanner driver or that device ensuring that the driver you use is the correct one for the operating system you are using
Feb 02, 2011 | Canon CanoScan LiDE 90 Flatbed Scanner
I have been using this canoscan Lide 60 for 2 years, everything was fine. but suddenly didn't work recently and told me "cannot communicate with scanner. Cable may be disconnected or scanner maybe...
Not a solution, but a confirmation. My Canoscan Lide 60 is no longer recognized by the system. It seems as though it does not power up. It gets its power from the USB interface. There is no "on" switch. Are there diagnostic tools available?
Jan 22, 2011 | Canon CanoScan LiDE 60
My Cannon Lide 90 only scans one document. try to do another it says ''the scanner is not available when in use by another application or user'' I close it all out, try again & same thing. I removed...
Check your hard drive space and system RAM requirements. Often this happens because there is not enough "Scratch Pad" space..OR RAM these days 4GB is too small sometimes.
Jan 28, 2010 | Canon CanoScan LiDE 90 Flatbed Scanner
Canoscan Lide 60 suddenly cannot be communicated.
hi um i don't know if this will actually work but it did for me, I had 2 problems with the lide 60 scanner-one was a connection/cable thing and another was this "TWAIN source thing" and after installing this:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
i seem to only have one....i think the connection/cable got fixed.
oh well, give it a try anyway :) cant hurt
Mar 11, 2009 | Canon CanoScan LiDE 60
CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
Jan 09, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
In spite of re-loading the software for my CanoScan LiDE 90, when I try to use it, I get the following message: "Cannot communicate with scanner. Cable may be disconnected. Check status.Scanner...
check this
go to File
print
see if the driver is there, if Yes right click on it and set as default
If no, then re-load when it says found new hardware.
Sep 17, 2008 | Canon Office Equipment & Supplies
Scanner won't communicate with my Mac
Uninstall the software with scanner unplug from your MAC. Install the software with the scanner disconnected, then connect it b4 the first use of the software.
Mar 28, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon CanoScan LiDE 90 Flatbed Scanner Logo
385 people viewed this question
old marine
old marine
