Question about Sport & Outdoor - Others
Ive got a JD-1-B jet ski and I want to pull the jet unit apart so as i can make it shorter so as to put it into a prototipe boat that im building .
3 Suggested Answers
heimlich
  • 1978 Answers
SOURCE: how to replace seal on a jet ski
The seals in the drive pump can be replaced by taking off the ride plate and pump housing. To replace any other seals (engine or hull) you will have to remove the motor from the hull.
Posted on Sep 03, 2010
heimlich
  • 1978 Answers
If the seal is in the jet pump, get an impellor tool and replace all the seals and bearings in the jet pump. You will have to pull the engine to replace the crankcase seals or the rear hull seal.
Why does it seem to be lacking power from low to high end?
Kawasaki jet ski - loss of "top end" power. ' Boat/PWC Lubrication ...
www.bobistheoilguy.com > ... > Boat/PWC Lubrication
Jul 5, 2011 - 15 posts
We have two jet skis, had them out yesterday for the holiday. Last fall, I prepared them for winter, as I always do. While getting the Sta-Bil ...
Nov 14, 2015 | kawasaki 2015 Jet Ski Ultra 310LX
My Yamaha Jet Ski 750, turned over Bro.. my Jet Ski, Yamaha 750, turned over and after that.. I pulled out of the water took the spark plugs out, put DW40 in the cylinders and nothing happened.. the e
sounds like you hydro locked it and possibly blew out a reed in your engine intake or worse, you may have bent a crank rod. But before you go tearing it apart make sure all the water is out of motor and theres none in the fuel tank then put in a new set of plugs and see what happens,
Mar 18, 2013 | Water Sport
What is the difference between a powerboat and a jet ski?
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Jan 17, 2013 | Boating
How Do I Turn Off Or Rewind Hours On 2008 Yamaha 1100 VX Jet Ski..Thanks cdm2164@gmail.com
Mate.You buy a new jet ski or don't sell it to anyone that wants a true ski.I will put your i.d. on a list.If you left the key on,you should,ve said so.
Jun 15, 2010 | Boating
I have a wnerunner 650 that porporis.s whe running fast.Can this be fixed. bobj199@hotmail.com
More weight forward can help. Many times people have dropped the back of there boat on gravel, a log, a board , etc. and have warped or curved enough to change the way the boat planes. Many boats are designed with ride plates that are too short. On most jet ski's if you were to extend the ride plate 4" (four inches) you would get a nice stable ride. Of course getting on and off the boat in deep water could get a bit more painful. 4" is the magic number. Shorter extensions would also help if angled correctly (just a longer flat surface)
May 03, 2010 | Yamaha 12V Air Pump
Can i put an 8 cyl 5 litre in a boat w/ an alpha 1 gen 2 drive with 1:81 ratio
Mate anything is possible you need an engineer who builds speed boats in you area. try your local ski club for the right tradie.
Apr 25, 2010 | Boating
See doo wont start
It should start on land more easily than in the water (no drag on impeller). However, you should not run your boat for more than 10 or 15 seconds dry or you might damage the motor (too much heat build up). If you put a flush kit on your boat you can run it as long as you want in your drive way. We always start are boats on the trailer for a few seconds before launching. It makes the first in the water start a lot easier.
Apr 02, 2010 | Encore Software Kawasaki Jet Ski...
Removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Jun 15, 2009 | Boating
Sport & Outdoor - Others Logo
22 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
