Question about Hotpoint Washing Machines
My hotpoint wt761 is okay on pump out but nothing happening on spin and showing no error code
  • reynoldstan Apr 04, 2011
    the drum still goes round on every other program but not spin and cant work out how to take filter cover off to check filter
    Genius:
  • Hotpoint Master
  • 1,466 Answers
Could well be worn motor brushes if no action from the drum>Common fault on machines over 4....5 years old...Parts cost around £18....Fitting quite simple...Good luck
Posted on Apr 04, 2011
  • Gerry Harvey
    Gerry Harvey Apr 04, 2011
    The filter is located middle of drum at the bottom its contained within the Sump Hose...Removal by means of a large nylon clip,you will the see the filter good luck
I have flashing lights on Hotpoint WT761 washing machine when I turn it on?
SOURCE: have a hotpoint wt761 washing
http://www.recommendedbuys.co.uk/household-appliances/washing-machines/hotpoint-wt761.htm
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,
Oct 05, 2014 | Washing Machines
Hotpoint wt761
Crash on progrmming
Apr 08, 2014 | Washing Machines
Hotpoint wt761 is showing error codes f05 and f011 can you help
Hotpoint (Indesit) 'f05' decodes as 'pressure switch stuck on full' and 'f011' as 'pump/draining error' which leads me to gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 25, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hi My Hotpoint WT761 is showing error code F05 which means a blocked pressure switch. I really havnt got a clue when it comes to washers but cant afford a call out - can you tell me how to check for...
If there is no filter at the front of washer, then remove the lower rear panel of washer, locate and remove the large black hose on bottom of drum, remove and clean filter inside hose.
please rate my solution.
Thanks.
Nov 03, 2009 | Washing Machines
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Wt761
The first thing to check here is by opening up the top of your washer. Plug off the mains. Check to see the wires are connected to the inlet valve at the point where the water enters your machine, tighten the wires. Then shut off the wall faucet, unscrew the hoses, check the fine mesh at the machine valve entrance, clean out. Refit the hoses carefully without cross threading, open the wall faucet full to check for leaks; advisable to keep faucet fully open. Check to see that there is no leak at the dispenser end of the pipes. You are done now, try the machine (with the top open, caution)
If there is still no water, just change the inlet water valve, you can do it yourself.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Have a hotpoint wt761 washing machine which is displaying a f-08 error code
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,,,,good luck and rate me
Jan 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
192 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
