Question about Bosch Refrigerators
My bosch economic cooler KDR3701GB KEEPS TRIPING THE CUICUIT BREAKER WHEN IT IS PLUGED INTO THE MAINS THE FUSE IN THE PLUG IS FINE ALL OTHER APLIANCIES ARE ALLSO FINE WHAT COULD BE CAUSING THIS PROBLEM
  • 69 Answers
SOURCE: cooler keeps on triggers breaker
If it is tripping the breaker, stop plugging it in. The breaker is tripping because something is wrong, and continually resetting the circuit WILL cause a fire. Either return the unit, or have an electrician look at it. You can also try plugging it into another circuit in your house to isolate the problem, but please don't repeatedly reset the breaker, there IS a problem somewhere.
Posted on May 27, 2009
richroth
  • 9472 Answers
SOURCE: the dryer keeps triping the breaker when pluged in
You need to check your power cord. Here is a video to walk you thru it.
Posted on Nov 26, 2010
  • 8909 Answers
SOURCE: Keeps blowing the plug fuse and/or triping the
That must be the mains cable or the filter box as it enters the TV.
The TV is fused internally so suspect the supply cable or mains filter capacirors.
Hope that helps.
Posted on Dec 10, 2010
  • 47 Answers
SOURCE: My Bosch economic cooler has
check for food or shelves protruding. Check if door is rubbing on the bottom, sometimes scrape marks are evident. check to see if gaskets are sticky if so clean them and apply thin layer of petroleum jelly. Depending on the model sometimes the closing cams are broken on the bottom hinge.
Posted on Apr 14, 2011
kevin_getz
  • 1031 Answers
SOURCE: henry geeps blowing fuse.why?
I would replace the whole unit itself. It's obviously shorting. What kind of vacuum is it and how old?
Posted on May 08, 2012
Circuit breaker
The only "circuit breaker" on this dishwasher is the 13amp fuse in the mains plug. Can you elaborate on the problem you are having with the dishwasher??
Mar 21, 2013 | Bosch Dishwashers
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
Breaker keeps triping
Did it work trouble-free before?! Is it on its own circuit?! Are you sure breaker is of appropriate rating?!
Jul 09, 2012 | Refrigerators
My Lazy spa keeps triping the plug when you press the heater function everything else works fine filters/blows this fault does not happen all the time sometimes ok but all of a sudden will trip and thats...
Hi, Try using another plug. Note: Don't use long extensions cords this will trip your breaker and could cause a fire. Have a electrian look at your set up.
Jun 27, 2011 | Garden
Keeps blowing the plug fuse and/or triping the circuit breaker when plug in? Been working fine for 5 years until now
Hope that helps.
Dec 10, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
The dryer keeps triping the breaker when pluged in and not runing
Nov 26, 2010 | Kenmore 72062 Gas Dryer
A hager b6 fuse has blown - normally the switch flips off and you push the switch back to on and power is restored - here the switch is limp and wont stay in the on position - i cannot see how you remove...
I have just done this myself and without blowing myself up.
1. Tools needed will be a torch and a philips screwdriver
2. Switch off your mains.
3. Check your mains are off
4. On the fuse itself they are two screws. One above the hager sign and one below. Unscrew these. The top screw keeps the wire in from the mains and bottom screw is to keep fuse screwed to the actual fuse box
5. You should be able to remove your fuse now
6. On your new fuse there will be a white piece at the back. Pull that down
7. When the fuse is removed you will see the wire which is now free and on the bottom a plug which is where your new fuse slots in.
8. Slot your new fuse on the plug and tighten the bottom screw.
9. Put your wire in place on the top of the fuse and tighten the top screw.
10. Switch your new fuse on the "on" position.
11. Put back your cover on your fuse box
12. Switch your mains back on.
WHO NEEDS A MAN! PS ONLY ATTEMPT IF COMPETENT OR GET A QUALIFIED ELECTRICIAN!
Sep 12, 2009 | Electrical Supplies
Cooler keeps on triggers breaker
May 27, 2009 | VinoTemp (VT60GNV) Wine Cooler
I have a Panasonic microwave model nn-sa616wx sn 58100747 it keeps triping the breaker after it operates for awhile we have taken a amp reading and it draws 17.2 amp.This is a new microwave.
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Jul 24, 2008 | Panasonic Microwave Ovens
Clothes Dryer not working
if it is tripping the breaker right away there is an issue with the drier shorting to ground. unplug and look for a broken wire in the drier. if the drier runs for 10-15 min maybe 30 before it trips the breaker. there is a loose connection in the wiring. either at the junction box in the wall behind the dryer or at the breaker panel. If it is in the electrical I would call an electritian. Good Luck!
Sep 24, 2007 | GE DBSR453EBWW Electric Dryer
Refrigerators Logo
43 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
