Question about Kyocera Mita KYOCERA/MITA - FS-3900DN Mono 37ppm, 400mhz Printer
FS 3900 "Unknow toner istall" shows in display?
  • patrikakesso Apr 11, 2011
    I have orginal toner !
  • 200 Answers
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Posted on Apr 11, 2011
  • Shawn
    Shawn Apr 11, 2011
    There is a RIF sensor in the machine that detects if the toner is a Kyocera toner or not. If you have the correct toner in the machine and still get the message that Unknown toner is installed then there is a sensor or a board problem.
Dark lines fs 3900
The lines are more than likely caused by either the Drum, Developer or Fuser unit. I have found in many cases that if non genuine toner is being used this will give you poor quality images. You can try using genuine toner which may resolve your issue but you may have to run a few hundred prints to clear out the old toner before the image improves.
Apr 15, 2014 | Kyocera FS-3900DN Laser Printer
6030 display
KM-6030 or FS-6030. if it is the fs open the fron door, remove the waste bottle and replace it with a new one (they come with the toner). if it is a KM or CS 6030 that should be covered under your service plan. if you are running a segment 3 machine without a service contract you need to reevaluate your situation.
Nov 28, 2013 | Kyocera Office Equipment & Supplies
Kyocera fs-c5400 toner usage
I don't think you are looking at coverage I think you are looking at toner levels
Aug 09, 2017 | Kyocera FS Office Equipment & Supplies
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
I have a Kyocera FS-2000D i've installed a new toner kit, but the printer is stuck on saying "please wait" adding toner.
Turn of the printer unplug and then turn back on.
Was the toner you installed a Kyocera toner or a after market toner? If it was an after market toner that could be your issue.
Feb 12, 2011 | Kyocera FS-2000D Laser Printer
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Jan 11, 2010 | Kyocera FS-3900DN Laser Printer
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
233 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
