A warning light that is a triangle made up of dots with an arrow pointing down on top of them has lit up. What does this mean?
  • 1,110 Answers
This is your add toner indicator. It means you need to change out the toner cartridge.
Thank You for using Fixya.
Posted on Apr 05, 2011
What does the triangle with the arrow round it mean and what does the triangle with the exclamation mark in mean please
The triangle with the arrow around it is for the wheel speed sensor. The triangle with the exclamation point is for tire pressure. Low tire pressure would set both of these lights off.
Oct 13, 2012 | Cars & Trucks
A orange light comes on, it has 2 arrows pointing towards a dot and it looks like they are in a pot without a lid. It is the top left warning light . What does it mean?
Refer to your owner's manual, it will be listed there, every vehicle is different. Sounds like possible low coolant light.
May 12, 2011 | 2003 Toyota Corolla
What does the warning light with down arrow (I know oil, water, and battery lights) mean?
On a saturn with a manual transmission the down arrow means to downshift to a lower gear and the
arrow pointing up means to upshift to the next gear.
Oct 29, 2010 | 2001 Saturn SC
A red light with an arrow pointing at a line appears off and on. what is this light mean?
ARROW POINTING DOWN THAT A LOW COOLANT WARNING LIGHT.THIS WARNING MEAN ADD COOLANT QUICK AS POSSIBLE OR THERE WILL SEVERE ENGINE DAMAGE.
May 17, 2010 | 1999 Oldsmobile Alero
What does the dotted triangle mean?
On most sharp copiers the dotted triangle that points up is Toner and if it has a triangle that points down that is Waste Bottle
May 13, 2010 | Sharp AL-1457 Black and White Copier
SEAT TOLEDO WARNING LIGHTS
Could be the motor-management-warning light, but I guess it's the break-warning light. There might be too little breaking-fluid left in the lines ... A boardcomputer-readout should clarify this.
Otherwise, try parking on an ascending road with the nose pointing up, hit the hand-break and wait like 2 minutes; the light should come on. You might wanna retry it with the car's nose pointing downwards as well ... If so, definitely the breaking-fluid, otherwise probably not ;)
In any case - flashing warning light are never ok, so when you see it again and you're sure it's not just the ABS/ESP warning light, go and have your boardcomputer read-out, since it should contain useful errorcodes ..
Feb 07, 2009 | Volkswagen Passat Cars & Trucks
Mini cooper Warning lights for abs, low tire,traction comes on
Ok, check the brake fluid level for a start. This could mean a few things. Your brake pads might be worn down, which would bring a yellow warning light on(triangle), at the same time with the pads being low it will have displaced the fluid, making the level low, this would be a red light on. Now because of this the body control module has detected these faults, will have turned the abs off, hence the abs light.
If brake fluid is low, this could confirm my theory.
If its low, top up with dot 5 brake fluid and take to garage to have new pads fitted.
TL
Jan 24, 2009 | 2007 Mini Cooper S Convertible
Dashboard warning light.
Check your tyre pressures , check your spare too . It should reset .
Nov 30, 2017 | Toyota Corolla Cars & Trucks
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
jasbo
jasbo
