Question about Fellowes P48C Cross Cut Shredder with Patented Safety lock
My Fellows P48C was shreading a load of single sheet A4 leaflets perfectly OK. After some 40 sheets it slowed to a snails pace but still shreded, unfortunately making a loud course rasping or growling noise. It sounded as if it was labouring severely. All the blades appear to be clear OK, and I did apply a little light 3in1 oil to the blades, but the problem stil remains. Is there anything I can do on a DIY basis or does this sound like needing a professional repair? Thanks. Bob Moodie
2 Suggested Answers
  • 6 Answers
There is probably astripped or broken gear inside the gear box.
Posted on Nov 11, 2008
I have a p48c fellows shredder blocked with credit card.It will reverse only but will not spit out card. It smells then gets too hot and light goes to red. Can I rescue this?
Your Fellowes shredder goes into thermal overload when it tries to digest the credit card. You will have to expose the mechanism and pick out the jammed plastic bit by bit. Despite advertising claims to the contrary, shredders cannot handle credit cards and plastic coated material. I have a Royal that claims "10X" capacity which translates into one "X" at a time with frequent pauses for cleaning out shredded material. I also have a Sylvania shredder which claims "9-sheet" capacity.That translates into one sheet at a time with frequent pauses to remove clumps of shredded material.
Mar 07, 2018 | Fellowes Office Equipment & Supplies
What are the criteria one should use to judge bed sheets?
There are some important parameters on which you can judge any bed sheet like-
Good Thread Count
Quality weave and finish
Good quality yarn with long staple cotton etc.
To purchase quality bed sheets in India, visit-
Jan 15, 2014 | Furniture
Remove paper from sheet feed when no paper loaded
It is possible that the genuine replacement HP sensor is defective.
Jan 09, 2014 | HP DESIGNJET T770 Printer
Windows 7HP and Epsom BX300F can scan but preview shows that, one a4 sheet is split into 4 or 5 random areas and will print those areas only on 4 or 5 seoerate sheets of A4. How do I change this so that...
Goto -> Printer's Property/ Prefrences 1 - "Layout" Tab -> Select Portrait in Orientation section. 2 - "setting" Tab -> Select A4 in Paper Size DropDown. 3 - Click OK and try.
Feb 16, 2011 | Office Equipment & Supplies
i can't tell you step-by-step how to fix as i don't know this particular model well, but i can tell you that you need to check your machines internal paper settings and most of all, make sure your "auto reduction" is set to "on".
Jul 13, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
Dec 20, 2009 | Dell 1320c Laser Printer
Size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
Nov 19, 2008 | Canon IMAGERUNNER 6570 Copier
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
It seems to me that the tray sizes are not programmed correctly. A4 size is european and and slightly longer than letter size. If programmed to A4, the unit will behave as you described.
Sep 06, 2007 | Dell 1600n All-In-One Laser Printer
Fellowes P48C Cross Cut Shredder with Patented Safety lock Logo
43 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
