VHS Grabber has very jumpy screen before I start VHS to record and when recording the playback is also jumpy.
    Problem Solver:
  • 8 Answers
Rewind tape then fast forward to the end as the tension on the tape is wrong.
PS put it in a rewinder machine ...ok?
Posted on Apr 04, 2011
Screen goes black as soon as i push record on dvd when trying to record vhs to dvd on magnavox combo player
Dubbing does the media transfer automatically, not by playback and record. you select vcr to dvd then do dubbing. Please read the manual. and try all the controls.
Feb 10, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How to plug vhs to vhs recorder
If they have a scart sockets simple connect them together viva a scart lead. Set one in play and on the other press the av button, select the socket the playback vcr is plugged into and you should see the picture. If you want to record it press the record button.
Ideally the none playback vcr should have two scart sockets. One connected to the TV and the other to the playback vcr.
Oct 04, 2009 | Panasonic Televison & Video
My VCR plays cassets perfectly, but recently I am facing recording problem. I am unable to record, I am seeing recording caption on my screen. But it is not recording.
Well I think that the the machines mechanical piece that allows you to record is broken then and needs to be fixed so we perfer DVD players and dvd disc;s instead they are better at recording and have less problems too.
Jun 18, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR recording
As with all tape related recording equiptment, the path the tape follows in your machine will collect debris which will interfere with the synchronizing playback signals originally recorded on our tape when first recorded. The "ROLLING" is the loss of those synchronizing signals and the "skewing" of the tape where the heads are now reading between the recorded information causing noise at the top or bottom or throughout the entire screen. SOLUTION for about 85% of machines exhibiting this problem is CLEANING and inspection of tape path alignment best done with a calibrated playback tape for accuracy. HOPE this helps . . . Jaszy
May 29, 2007 | Maxell 10 Pack T60 Blank VHS Tape PI PLUS...
Noise block doring playback of D-VHS tapes
* Do not record program in DVHS mode on an S-VHS cassette. Use of S-VHS cassettes will not allow for maximum performance and may result in head clogging. Use only D-VHS cassettes as recommended in the instruction manual on page 27. * Make sure that the DIGITAL 3-DNR lamp is ON when playing back a cassette recorded in D-VHS mode. If not press DIGITAL 3-DNR so that the DIGITAL 3-DNR indicator illuminates. * When block noise appears on the TV screen, clean the video heads with the DFC-2 D-VHS Head Cleaning Cassette (continue up to 3 minutes total). Please refrain from using any other head cleaning cassettes as drum damage may result.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
