Question about Zanussi Microwave Ovens
We have got Zanussi Fridge/Freeze, water from the fridge area keeps running under the vegtable's drawer area, which I need to wipe/clean constantly.
    Genius:
  • Zanussi Master
  • 1,474 Answers
Check that the little drain hole at the back is not clogged it sounds like this is the case,its easy to clean try something soft like a straw to push in to clear, Normally I get a mouthful of hot water and squirt this down the straw,Works well for me...Good luck.
Posted on Apr 04, 2011
Zanussi freezone fridge freezer
Try adding freeon made for refrigerator. Can get at any hardware store. Hope this help.
Sep 09, 2013 | Microwave Ovens
I have a side by side fridge and the freezer side just keeps on running like all. The motor is really hot and the floor under the fridge is too.
Sounds like the compressor starter is locked up and needs to be replaced. Or the thermostat is either stuck or the contacts have melted together and it will continue to run till replaced. You can unplug it for a while to see if cooling down will help but if not then you will have to use the plug as the on off switch till you get it replaced. Is the fridge cold? is there ice built up all over the coils, this also might cause the issue if the coils are froozen and the unit is running but not cooling. The freezer is what cools the fridge so if the fridge is not cool then there may be a problem with the coils.
Here are some trouble shooting tips.
www.acmehowto.com/howto/.../refrigerator/diagrefrigerator.php - CachedSimilar-
Jul 10, 2011 | Microwave Ovens
We have water leaking from the back of the frige, coming from under the area where the copper tubing connects from the wall to the actual refrigerator. I can't identify exactly what's leaking. I doesn't...
This can be an auto defrost condition. If your fridge is auto defrost, what happens during the defrost mode, ice build up is heated (in the area immediately near the evaporator coils, not in the main area) . This ice becomes water and drains out via a small tube, typically at the back or bottom of the machine. This water normally goes into a pan under the fridge, and evaporates without the user being aware of it.
If anything causes excessive ice build up (opening the door too much, door seal leak, etc.) then you get too much water and the pan overfills and spills out.
I suggest that you remove the pan from under your fridge, clean it, and put it back, and test to see if yo actually have anything wrong, or not.
This leak would NOT be refrigerant, as you would cease cooling if so. it is all condensation, which is physics and normal...
Mar 20, 2011 | Microwave Ovens
Kithenaid superba fridge has water pooling inside under drawers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 07, 2011 | Microwave Ovens
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Fridge not working but freezer is ok!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 24, 2010 | Zanussi Microwave Ovens
The freezer constantly drips water even with the ice maker turn off, the fan constantly runs but when the door is open the fan shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 07, 2010 | Microwave Ovens
I have an intergrated fridge freezer and the water keeps freezing over the little hole at the back then the water drips down the back of the fridge into my veg drawer I have turned the temp down but this...
Common problem with fridges. Suggest you get behind the fridge and somewhere on top of the compressor, there is a small pipe that normally sits in a pan of a sort. You need to blow hard into the pipe which will release the blockage in the system and that will clear the line. Water will then start draining again onto the compressor. That will stop the water build up in your fridge.
Aug 08, 2010 | Microwave Ovens
Microwave Ovens Logo
62 people viewed this question
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
