Question about Panasonic Videoprojector PT-LM1E Multimedia Projector
I have replace the lamp but any how i am not getting any response from projector. As after replacing the lamp projector was ok. It shows all the thing but second time. No response. pl suggest
  • Panasonic Master
  • 6,694 Answers
you didn't mentioned any thing about the indications. is there is any indication on the projector. if projector have some problem it will show the indication for the same using its self diagnosing system.
just do one thing check the power cable and the power at the socket to which you have connected the projector. if these are ok and the projector have no indications on its panel, then the smps power supply in side the projector have some problem. if so it is difficult repair the smps by the user. need good knowledge of electronics servicing, because there is harmful high voltage points.
Is there is any indication on its panel, then if you discribe the same will provide you the exact solution .
Also try to check the inserted new lamp , lamp cover is it properly closed etc.
if the projector starts try to reset the lamp hour
1. Go to its menu select option2
2. From the option 2 menu select lamp runtime
3. Press and hold the enter button for approximately 3 seconds
4. After resting just power off your projector and turn it on again.
Also check one more thing
The "CONTROL KEY" may be set to "OFF". In order to set the "CONTROL KEY" to "ON"
without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
ok
Posted on Apr 04, 2011
I replaced the lamp, it worked for 5 days, now when i power it on, i get no light
it could be due to an incompatible lamp which has blown once again or it could be due to a faulty ballast
open the lamp and see if all looks good!
if lamp looks ok, u need to check the ballast,
before that just do a quick check on the small switches which are under the filter cover.
if the cover locks have got damaged then the switches will not close and hence show a similar problem.
this is the most common problem with SONY projectors
May 28, 2015 | Sony Projector Lamp for VPL-HS51
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Lamp has reached 3000hrs switches off projector.How do I get the projector to stay on as the picture is ok?
That's a safety built in, telling you bulb needs replacing. there's no overide switch or function. Bulb needs replacing.
Jan 07, 2011 | BenQ Projector Lamp for MP720p
I need to replace the projector bulb
hi,
for replacing the lamp do the fallowing.
1 turn off the projector and disconnect the AC power . allow the projector to cool for at-least 45 minutes.
2. remove the screw at the bottom to oppen the lamp cover.
3. after that remove 2 screws of the lamp and pull out lamp by grasping the handle.
4. replace the lamp with a new one and tighten the 2 screw s back in to position make sure that the lamp is set properly. replace the lamp cover and tighten the screw.
5. connect ac power turn on te projector and go to the menu select lamp counter make it zero
Replacement lamp type number is : POA-LMP90
OK
Dec 15, 2010 | Sanyo PLC-XU73 Multimedia Projector
Reset option killed the yellow warning to replace the bulb, but didn't reset timer...it's still showing 4,400. I bought new replacement lamp from www.electried.com, but it's showing dark. Is it the lamp or...
The projector's lamp cover might not be securly on or you might need a new one, or the projector has blown a fuse that can be replaced other wise it could be your projector but be sure to contact your sony dealer first.
Feb 09, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Projector light not on
check the lamp. if the inside has bulges, black spots or fogging, replace the lamp and reset the lamp timer (through the menu). if the lamp is ok, listen for a high-pitched whir when you start it up. if you don't hear one, replace the colorwheel. if that and the lamp are ok and you get the fans on, replace the ballast. you could get the part from an infocus service center and do it yourself, or you could send it in to them and let them do it. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 16, 2009 | InFocus LP70+ Multimedia Projector
Infocus lp420 powers on (can hear sound) but no
if you get no leds, it's the power supply. if you get fans, it may be the colorwheel. if the colorwheel is ok, it's the ballast.
Nov 28, 2009 | InFocus LP400, LP420 and LP425 (Not z)...
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
PJ-TX100 Projector won´t start up out of Stand-By
Hi Mario
If there is no response on the Projector it normally means that the Mainboard is faulty.
Check if your machine is still under warranty because this quite expensive to replace.
As far as the schematics are concerned - I'm unfortunately not able to help you out with that.
Apr 02, 2008 | Hitachi PJTX100 Multimedia Projector
Panasonic Videoprojector PT-LM1E Multimedia Projector Logo
170 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
