Question about Microwave Ovens
I have a error 5 on my primea touch. I have read a solution to solve this problem "That means prime the water circuit. It should prime by itself. If the machine is making noise and still failed to prime, you can do it manually by going into test mode , set the multi valve to hotwater position and operate the pump . When the water flow freely turn off the machine and restart it. Hope it will help." But I do not knox how to go on the test mode. Thx for your help
3 Suggested Answers
MerlinTech
  • 197 Answers
SOURCE: powere went out and i
sounds like the main control panel..
Posted on Jun 20, 2008
SOURCE: my new gaggia platinum vision
We had the same problem on our machine, and it was fixed by backing the strength setting (the physical dial on the front of the machine) off from the "maximum" setting a small amount. Somehow this was creating too much back pressure, and the useless "will not prime" message appeared.
Posted on Feb 17, 2011
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
It says -TE- , what does it means?
TE error code indicates that you have a problem with the touch keypad communication between the control panel and the main control circuit board. You could try and see if you have a "gunked" up touch panel, if the ribbon cables are still okay and properly seated.
Nov 07, 2014 | Microwave Ovens
Error report on panel
That error means that the touch panel is sensing a button that is stuck down. The touch pad might have a short in it.
Jul 17, 2013 | Samsung Microwave Ovens
HELLO. I HAVE A GE MICROWAVE MOD JE1860WB. THE MONITOR READ "F3" CODE. WHAT IS THAT?
The F3 code means that the Key panel also called touch pad is shorted. This code usually comes up when when the Microwave detects the shorted panel continuously for over 60seconds.
To correct this error, you have to Replace the key panel also called the touch pad.
Thanks.
Sep 14, 2011 | GE JE1860 Microwave Oven
My new gaggia platinum vision will not prime. it says "prime water circuit" and makes several loud clicking sounds and then says "restart to solve the problem", but this doesnt solve...
Dec 29, 2010 | Microwave Ovens
My microwave stays on (won't shut off unless door is open); and it reads "F6 error"
"F6" means you have a shorted cook relay on the control circuit board.
You can order and install a new control circuit board (part # 8183726 (aka AP3038853) ) from the Pros here for $205.88 plus shipping.
But also, we regularly see and repair this problem for folks nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 02, 2010 | Whirlpool MH2155XP Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Kenmore Microwave Oven cooktop light
Turnaround is usually about a week "door to door".
The problem is on the circuit board, but we ask that you send the control panel assembly, by which we mean the plastic control panel frame, keypad, and circuit board as an assembly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 23, 2008 | Microwave Ovens
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
