Question about D-Link DIR-300 Wireless Router
I m getting error on my dir-300 :network cable unplugged" and only power light is indicated. No other lights blinking. What to do? I tried to reset several time but not worth..
    President:
  • 2,340 Answers
Check or test your network card, RJ45 network cable & Router one or any of the parts could be faulty. ie if you are having the "network cable unplugged"
1. If your network is onboard, your can use a USB or PCI network adapter installed to your PC to test it on your router.
2. For your RJ45 standard network cable, you can use a Network cable tester to if the cable connection is OK.
3. As for the router, test it on a PC with working network port to verify if the router network port is working.
Hope it helps.
Posted on Apr 04, 2011
  • 1,719 Answers
1. Make sure the LAN/ Ethernet cable and RJ-45 connectors at both ends of the cable are fine and the cable is not damaged.
2. To identify the problem, try a short cable and another PC/ Laptop
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
  • mtugras Jul 04, 2011
    when i using different router, it's working but when use d link dir-300, just power light and there is another light which is like hexagon is blinking
Epson wf-7520 power light, auto answer light & wi-fi light blink
As far as the wifi is concerned, try getting it connected to your home network. Once it gets connected, go into your network settings and try to get the IP address. If you can obtain that, you should be able to add a network printer using TCP/IP port. Also, see if you can factory reset the printer, and start the setup all over.
Feb 17, 2014 | Epson WorkForce WF-7520 Wide Format...
Blinking light on d link router
what is indicated below the blinking lite...if your not getting a signal...try unplugging the units power...wait 4-5 minutes and plug it back in and see if it resets itself....phillip
Jul 04, 2012 | D-Link DIR-615 Wireless Router
Internet light/port lights flashing on WPN824 no connection
Try goto windows logo
in search box type cmd
when you get to black screen type ipconfig /release
when that finishes type ipconfig /renew
see if that resolve it.
Jan 12, 2012 | NetGear RangeMax WPN824 Wireless Router...
When I plug in the router, the power light comes on steadily, and four other lights are flashing. The light that looks like a globe, and the lights shaped like computers numbered 1-4 all start flashing. ...
On page 6 of the DIR-600 user manual, try pressing and holding the reset button for 30 seconds using the tip of a ballpoint pen to factory reset the router.
If that does not resolve the issue, then most likely your router has failed and will need to be replaced. This DIR-600 router became End Of Serviceable Life on December 1, 2009.
Dec 21, 2010 | D-Link DIR-600 Router
Dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
May 22, 2010 | D-Link DIR-300 Wireless Router
DIR-615 , power led blinks always, wifi and internet not working
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
5. check the power adapter it may be faulty.
Apr 28, 2010 | D-Link DIR-615 Wireless Router
Dlink DIR-625 Doesnt work. Power light blinks when plugged in
hi.. all,
i am facing the same issue.. my new DIR-615 , when plugged with power cord ... make the power led blink continuously... and hence so, no network is accessible neither wifi works in simple terms noting works, no combination of power cord with network cable with computer works.
i have even tried resetting using the reset button.. but still the power button keeps blinking.
and yes it was working in past, its a brand new product(3 months old).
Please help and its urgent..
thanks a lot for your help..
Regards
Dharmendra
Nov 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
My D-Link DIR-625 is constantly toggling between conencted/&not
it's possible, i would try moving the computer to a diferent prot on the router and also pluging in a diferent computer, you could also have a bad cable. if it won't work with another cable on another computer then you will probably have to buy a new router. if it works with another computer you will probably need to replace your pc's network card. (though i would try reinstalling the driver first.)
Aug 18, 2009 | D-Link DIR-625 (790069292637) Wireless...
MSI wireless G RG60G fast bliking wan.
hello!
fast blinking wan light may indicates that it receiving or sending data. try the ff and see if this may work:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 24, 2008 | MSI Wireless-G RG54G3 Router
D-Link DIR-300 Wireless Router Logo
178 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
