Scanner dose not want to scan - Office Equipment & Supplies
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
My hp 1522nf dose not scan
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Feb 11, 2010 | HP DeskJet F380 All-In-One Printer
E02 in canon Np 160
I believe a E02 deals with the scanner. Your copier is very old. It has been a long time scine I've worked on one. Have you checked that the exposure lamp has continuiy? If so, you may have a blown thermal fuse for the scanning lamp. Also, dose the scanning lamp turn "ON"? You may have a broken scanner lamp power cable. You should be able to order the parts on line.. Good Luck...
Dec 27, 2009 | Office Equipment & Supplies
Problem with my os vista and my 3300u scanner
it dose not recognezed
disable usb 2 controler and see
Aug 18, 2009 | Acer Scan to Web 3300U Flatbed Scanner
It will not scan.Led light dose not come on.When i slide the scanner nothing shoes up in the window.Then the rabbit apears.THANK U. so very much for your help. This is all new to me. BEST REGARDS JEANNIE...
I had a Scan n Sew several years ago...the rabbit means you are not moving the scanner fast enough. The turtle means to slow down. Or it could be reverse? Sorry it's been a long time.
Jul 22, 2009 | Janome Sewing Machines
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
My motherboard dose not support epson 1500 scanner it give code error
What is the full model of the scanner?
Try another USB port ,also uninstall and reinstall the software from the CD or download the latest driver for it and only plug in the scanner when the installation has finished.
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes&expansion=0010000#scan
Apr 22, 2009 | ASUS M2N-MX Motherboard
I have driver cd but USB driver dose not support to window vista
dear windows vista not support this driver .please install widows XP and install usb driver.
Feb 08, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
Feb 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
SC101 ERROR MESSAGE
I'm not familiar with your exact model but for small ricohs....Sc101 means that the standard white level was not detected. When you first turn on your machine the scanner scans a white plate (you will find this plate under the glass or frame near the park position of the scanner (facing down towards the scanner).The scanner will try to take a quick scan of this white plate so it knows the difference between white and black.
You will get this error if anything is preventing the scanner from seeing this plate (exposure lamp not working, Blocked scanner, or more likely a dirty white plate.
Remove the glass, get a mirror and try to find the plate and then clean it with windex. When you turn on machine the scanner will try to scan this white plate( make sure scanner is not getting hung up on anything.
For original size your machine may use paper size sensors that look like small black boxes with two black eyes (under the glass looking up towards the original) make sure these eyes are clean.
Regarding your doc feeder I need more info ( does it attempt to work, etc) describe what it does when you try to use it.
Jan 26, 2008 | Ricoh Aficio 1018D Copier
26 people viewed this question
k24674
