Washing Machine Samsung front laoder 8.5 kg q1235s the cycle is finish and the machine had "End" displayed. when I came to open the door, the ahndle of the door either broke or came undone, both ways I cannot open the door. I open the box on the bottom and pulled on the orange cable, I can ehar the click inside the machine but still cannot open it because ot the handle, I tried to push a screw driver in the door to push the latche but nothing seems to be working. is there a simple way to open the door without having to open the machine itself or having to call for help from samsung?
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
  • 1294 Answers
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 11, 2009
SOURCE: can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Posted on Jun 26, 2009
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
Samsung Wf8804RP washing machine
hello - my door won't unlock at end of cycle on Samsung wf8804rp - its finished the cycle and the clothes just need taking out but the padlock is flashing and door won't open, I have tried turning it off for and hour and also doing a drain and spin but didn't work , many thanks
Feb 09, 2011 | Washing Machines
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Jan 17, 2011 | Hoover AAA160 Front Load Washer
My samsung washing machine indicates the door is open yet its closed whats wrong
the door switch is broken or a wire has come off take the switch unit out and check its connected then check it to see that its working if you dont know how to take it to a service shop they should test it for free and tell you if it needs to be replaced then you can order one from your nearest samsung auth repairer.
hope this helps
merry christmas
please rember to rate this advice thanks
Dec 07, 2010 | Samsung WF337AA Front Load Washer
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Spin cycle wont work and error code 8E comes on display on Samsung Q1235S
It doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Aug 05, 2008 | Samsung Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
