Question about De Dietrich DOP390 Pyrolytic Electric Single Oven
I have a De Dietrich oven F 4449 E. It has stpped working and there is an error sign ER 3 displayed. In fiddling with it I have now locked the door! Any suggestions please?
SOURCE: Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Posted on Jun 16, 2008
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
e-Guru
  • 3917 Answers
SOURCE: HOW TO UNLOCK THE OVEN DOOR
In order to unlock the oven you need to perform the following:
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
Thank you for contacting Fixya.com
Posted on Aug 07, 2009
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
SOURCE: De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Posted on Jun 30, 2010
I cannot unlock de Dietrich oven model ump504e1
Unplug the oven from power for 5 min to see if the lock will reset.
Nov 19, 2016 | De Dietrich Ovens
How do I fit the oven handle back on?
many have done this having never seen a De Dietrich stove /oven I can only guess that you need to separate the door halves to put the screw back in place . and I would use some LOCK TITE on it
Oct 01, 2014 | De Dietrich Ovens
De dietrich induction hob fault code d5 6f 20 a3
I have a De Dietrich DTI749X induction cooktop and i have the FO error code flashing on two of the hobs.
How do I fix this?
Sep 01, 2011 | De Dietrich Ovens
How do i unlock a de dietrich oven?
Jun 25, 2011 | De Dietrich Ovens
I got a key sign on the screen and since then I cannot operate the oven
This is telling you that the oven is locked. You will need to unlock it to use it.
Mar 18, 2011 | De Dietrich DOP390 Pyrolytic Electric...
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
Aug 07, 2009 | De Dietrich Ovens
Mar 31, 2008 | Ovens
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
De Dietrich DOP390 Pyrolytic Electric Single Oven Logo
230 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
