Question about LG Flatron L1710S 17" LCD Monitor
When i switch on the computer, the only thing that appears on the screen is "power save mode on". i have checked all the cables, i changed monitors, but no solution for the moment thanks for any advice
    New Friend:
  • 68 Answers
Other OPtions:
- Try cleaning your video card, (if there is), open your PC then erase its pins with an paper eraser.
- if you are using a built in video card then clean the memory, remove your memory then erase its pins with an paper eraser, return the parts and make sure it is properly placed..
good luck and don't forget my rating, thanks....
Posted on Apr 04, 2011
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
Im assuming the monitor worked OK until now. The two things I can think of is, First is the cable from the monitor to the computer is either not connected tight either on the monitor side or the computer. The second thing I can think of is a bad video card. I think the monitor is ok because your getting the power save mode on the screen.
I hope this helps you out, if it does please leave me some positive feedback.
Hi. I have a FLATRON W1934S computer. Every time I switch it on it says "power saving Mode". How can I fix it?
Hello, I didn't understand the problem.
1.After switch on and it goes to power saving mode , which can be visibly seen by changing the color of power led from green9or blue) to yellow.
First thing to be done is when it goes to that state "power saving mode" remove the video VGA cabl , and if the unit gives video message "no video signal" which stays for a while and usually goes again to power saving mode , this is OK,
So if there is no video signal on input it should work like this. so you have to check you PC.
Another way is to use laptop or other PC to check the monitor itself.
Hope this helps a bit
Oct 29, 2014 | Computers & Internet
FPD1930 gateway monitor powers up then a small box saying power save mode appears then it just goes black what's wrong with it
Hi. power save mode being displayed by the monitor could be caused by 3 things.
1)VGA cable to monitor is unplugged - check connections at computer and monitor
2)video card has been partially dislodged from motherboard socket. -remove computer cover and ensure video card is firmly pushed down into motherboard socket - do not use excessive force.
3)Monitor does not support video settings on the computer. - to fix on PC, turn on computer and press F8 button a few times during bootup - Windows will go to bootup screen - select SAFE MODE and hit enter. follow onscreen instructions - dont worry about weird colours and huge desktop icons - this is simply to get you going. Right click on desktop, select PROPERTIES>SETTINGS TAB. select screen resolution 1024*768 0r lower, select Apply or Ok. Now restart your machine
Dec 08, 2012 | Computers & Internet
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
I cannot get my Dell E173FP out of Powersave. I switch on the computer, but nothing appears on the monitor screen. I press the menu select on the front of the monitor and it says "In Power Save mode,...
Hi Ron,
It sounds like the monitor is not receiving a signal, or that the signal is one that it can't display (wrong screen resolution etc).
Can you make sure the monitor cable is securely plugged in at the monitor and the PC?
Do you have another PC you can try with that monitor?
Do you have an spare monitor cable you can try?
Is this the only monitor connected to your PC or are you using is as a second monitor?
I'm happy to try and help you solve this.
Kind regards,
Chris
Mar 05, 2011 | Dell E173FP 17" LCD Monitor
Hello, Hi, I've just got myself a brandnew Dell desktop with windows 7 32 bit on it. Everything seemed to work fine, but my computer enters Power saving mode at completely random times while im actually...
The simplest thing to do, as it is a desktop computer, is go to the control panel, power options and set everything to never so the computer never goes into standby mode.
If this does not prevent the machine going into standby mode then we need to perform further troubleshooting.
Jan 29, 2011 | Computers & Internet
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
My gateway monitor shows a picture for about 1 second then turns to blacked out screen with power light still on. I can shut the power off on the monitor then turn it back on only to have it do the same...
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Hope that helps.
Nov 01, 2009 | Gateway HD2201 22" LCD Monitor
Satellite A105: I am trying to instate new Linksys software, cd drive tries to spin the disk for a couple of minutes and then shuts off. If I rt-click on cd drive in "My Computer" then click on "Open" I...
You can configure your router without the setup disk , or you can talk to linksys tech support at 18003267114 - (very good free support ) or you can follow these directions :---
After making the conection
Please Double Click on the Internet Explorer and on the Address bar,
type in 192.168.1.1 and Press Enter.
Leave the Username blank and type "admin" in the password.
Step 04:
Configure Wireless Settings:
1. Please click on Wireless tab on the router's setup page.
2. Make sure that the Wireless Network Mode is set to Mixed.
3. Change the Wireless Network Name or the SSID from Linksys into your name.
4. For the Wireless Channel, please change it from 6 to 11.
5. Enable the Wireless SSID Broadcast
6. After that, please click on the Save Settings button.
Apply Security Encryption
1. When the router's setup page appears, please click on the "Wireless" tab.
2. When the Wireless area appears, click on the "Wireless Security" sub tab.
3. When the Wireless Security area appears, Change the Mode to WPA personal.
4. Enter the password of your choice in the WPA shared key (it should be minimum 8 characters) and then save the settings.
Step 05:
1. Under Basic Setup tab and set the "Internet Connection Type" to
Automatic-DHCP. After that, please save the settings.
2. Click on the the MAC Address Clone sub tab.
3. In the “MAC Clone” section, set the option to Enable.
4. Click on the Clone Your PC’s MAC button.
5. After that, please save the settings.
Step 06:
Power Cycle:
1. Unplug the router’s power cable.
2. Unplug the Broadband modem’s power cable.
3. Wait for 30 seconds.
4. Plug in the Broadband modem’s power cable and wait for its
lights to stop blinking.
5. Plug in the router's power cable once the modem’s lights stop
blinking.
6. Finally, Test the Internet connection
Mar 20, 2009 | Toshiba Satellite P105-S6104 Notebook
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Viewmeter on Viewsonic crt monitor
just check the power cable from the monitor is connected correctly and plug from cpu to monitor is connected properly be sure is there an loose contact... if it doesnt works means then give reset button in monitor... check the power and frequency control properties in bios .... may be properties is user define or is in maximum saving mode just change it to mininmum saving mode ...it will work...
Feb 06, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
LG Flatron L1710S 17" LCD Monitor Logo
70 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
