Question about Altec Lansing XA3051 Computer Speakers
No Sound at all,no remote cable for control. I need a complete circuit diagram of Altec Lansing XA 3051 for my repair and fix. Thanks Hery Gunawan
5 Suggested Answers
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
  • 185 Answers
SOURCE: Need the pairing code for bluetooth device to my Altec Lansing
Hi if your intentions are too connect your Phone to that bluetooth device , The paring code is what you make it , when you connect the two device's together , When you search for devices it will ask you to pair with that device , and you make the code anything you wish....Otherwise have a look at the manual under connection , it should have .
I hope this helped bud
Happy new year
Posted on Jan 01, 2010
  • 4 Answers
SOURCE: need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Posted on Nov 11, 2010
I need a wiring diagram fo computer speakers,Altec Lansing Multimedia FM501011854B
You mean the internal schematic, as in diagnosing / repairing a fault?
Google is your friend.
Look in images section of your browser after entering "altec lansing FM501011854B, schematic".
OEM's / Original Equipment Manufacturers as a rule usually don't post full circuit diagrams of their products on the web, to avoid competitors pirating their products.
But you may come across the schematic on a site that stocks service /repair manuals.
Otherwise search for Altec Lansing (Consumer Electronics) website.
Oct 13, 2017 | Audio Players & Recorders
Altec lansing t612 thumping noise
Your speaker is sensitive to subsonic transients produced by the amplifier driving it.
Jul 15, 2016 | Altec Lansing T612 - High End Speaker...
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
Jul 03, 2010 | Altec Lansing BX1020 Computer Speakers
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Altec Lansing XA3051 Computer Speakers Logo
67 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
