Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Hi, I have a Rinnai 417 Convection heater. It runs for about a couple of minutes and then switches off. The filters are clean and I have thoughly cleaned the 2 ignition ports inside the heater. I have tried everything except having *** with my wife and abusing my mother-Inlaw (Maybe I should try that) and have come to a dead end. Any suggestions as to what the problem may be. Does this model have a pilot light and if so, could that be the problem? Kind regards, Peter
  • peteris219 Apr 05, 2011
    Hi , Yes I checked all the connections, wiring and the sensor. Still no luck. I assume that the sensor is the one in the middle of the unit under the front cover and the other 2 at each end of the unit, are ignition ports.
    ind regards,
    Peter
  • 5 Answers
Have you checked the thermostat & wires making sure they are not loose or only partially connected
Posted on Apr 04, 2011
How can I clean inside a rinnai convector 417 gas heater
http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
How do I clean inside my rinnai convector 417?
The owner's manual at http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf on page 10 says to vacuum both filters weekly. It also warns not to wait for the filter lamp to come on since overheating may occur.
May 03, 2014 | Rinnai Water Heaters
I have a Convector 417 RC-417-80 that starts fine but after about 5 minutes stops working. Any ideas?
Steve, there are a several of basic things that can cause this problem.
1. Air filter is clogged. Turn electrical part of unit OFF, Remove and Clean Filter, if necessary.
2. Air intake obstruction. Look for air intake obstruction around the front of the heater.
3. If your unit is a flue-less heater, Oxygen Depletion Sensor (ODS) may be partially clogged with
dust, link or pet air. Clean Pilot Assembly using canned compressed air with a straw nozzle (like
you clean your computer with).
4. Gas pressure fluctuation to the heater. This will require a service call from an authorized Rinnai
Service Technician,
Hope this helped you to troubleshoot and solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
Rinnai energy saver 1001ft try to on unit power on light shows,fan starts,times out,fan on again then shuts down. no flame indicator showing. problem? regards peter
There are a couple of things that can cause ignition problems:
The exterior direct vent termination may be clogged.
The gas line shutoff is not turned ON or is only partially open.
The filter needs cleaning. Be sure to turn the Master ON/OFF Switch to OFF before removing the filter. Leave it Off until the filter is cleaned and replaced.
All the above problems you can troubleshoot and solve yourself. The ones below, require an authorized Rinnai Service Technician to solve.
Spark ignition failure.
Faulty solenoids.
Faulty Flame Rod.
Jun 02, 2011 | Rinnai Heating & Cooling
Evening, Rinnai Convector 417 - the two flames on the right hand side panel are on - heater tries to light but switches off before igniting we have cleaned the filters - seems to be no spark
There are about 8 reasons why this is happening. Rater than going into each and every one, I have included a link to an Owners Manual, that under the Troubleshooting Sections (pages 12 & 13) it will provide you with the scenario and how to solve the problem. This manual may not be the exact same one as your heater, but they all work the same and have the same problems.
http://www.rinnai.us/documentation/downloads/RHF265-1091X0101_202FTA_265FTA_Manual.pdf
Hope this helps you to further troubleshoot and solve the problem.
Apr 27, 2011 | Rinnai Heating & Cooling
Heater starts and runs for several minutes and then turns off
Since the unit runs for a couple minutes, I would first check for proper water flow. Find the pressure switch. It is usually round with two wire terminals and a copper/metal tube attached to it. With the wires attached, use a jumper wire to bypass the switch. If it runs longer check for flow problems.. (WARNING don't jump the switch for too long!!! Just enough time to see if the run cycle improves). Clean all the skimmers baskets, pump basket, backwash the filter (if a cartridge filter clean the filters). Try firing the heater again. If it still shuts down, replace the pressure switch. I never recommend adjusting it. Adjusting it too low can damage your heater and/or cause injury.
Jul 21, 2010 | Hayward 250K BTU NATURAL GAS POOL HEATER...
Shuts house circuit breaker off shuts house circuit breaker off
Breakers can get worn out and trip when they didn't earlier.The wires to the breaker can work loose over time.
Apr 24, 2010 | Heating & Cooling
Need to convert rinnai convector 417 gas heater from propane to natural gas, are the nozzles available?
Rinnai New zealand conversion kit number, R1852.
VERY complicated - get a qualified gasfitter to do it.
Jun 10, 2009 | Rinnai Vent Free Gas Heater/
RINNAI CONVECTOR 417 Natural gas heater 17.5 MJ Wanting to know if this is a decent model. Anything that may cause you to avoid buying this model? And about how old would this model be?
The 417 service manual is dated 2003, so they're no more than 7 years old.  You can download the operation & service manuals here:
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/161.pdf
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/161.pdf
May 06, 2009 | Heating & Cooling
Rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
221 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
