Question about Kenwood CD-223M 200-Disc CD Changer
Hhmy Kenwood cd-223m multiple cd changer wil not read disks, It reads "Disk Error" . I was told adjusting the dial on the side of the laser eye can correct it. And if so to what megahertz. In addition the cd drive motor does not engage while trying to read the disk, So should the cd spin while it is beeing scanned?
4 Suggested Answers
  • 36 Answers
SOURCE: CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Posted on Dec 31, 2007
mjap
  • 107 Answers
SOURCE: Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Posted on Jan 30, 2008
dunnbiker
  • 8546 Answers
SOURCE: I have a 1999 f150
Advice...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
Posted on Feb 05, 2011
What is the most likely cause of a "NO DISK" error with the Onkyo DX-C390 6-Disk changer? Would it be the laser pickup assembly?
Could be dirty laser lens, dying laser, faulty component,
Due to the complexity of multi-disk changers, it may be best to have the device looked at.
You can try running a cleaning disk through it first, but from your post, it sounds like this unit may have multiple problems and need tested by a physical person.
Nov 24, 2014 | Onkyo DX-C390 6-Disc CD Changer
Cd changer cannot read cd
Its laser pickup assembly might be faulty. Click here to know more about how to clean it. Do it once, and if it do not help you, replace it with same type and number.
Sep 03, 2012 | Audio Players & Recorders
My cd doors wont open what can do.
Hi.
Try disconnecting power. Connect back and then turn the DVD on by using the button in the player (not the remote) while at the same time you keep pressing repeatedly the eject button on the player. You will need to keep pressing eject until the unit start loading the disk.
If that does not work, then the DVD must be disassembled undoing the screws holding the top cover in the chassis.Once disassembled there is usually a disk stuck inside the drive or a mechanical issue. The disk tray motor rarely fails.
Do not disassemble the player unless you have repair experience. Before proceeding check warranty status.Call Kenwood if you want to book a repair
Regards.
Ginko.
Feb 03, 2011 | Kenwood CD-223M 200-Disc CD Changer
My navagation system keeps saying that it "cannot read disk" please check disk. Do i need a new disk or is something wrong with my system? 2006 Jeep Grand Cherokee?
the the problem is from the laser (lens) of your navigation system. It cannot read disk because the laser (lens) is weak or dirty.
Its might also be that the disk you inserted into the system has some scratches or the disc is bad. Try several discs on the system.
If problem still persists after trying several discs, get the laser replaced and it should read disk again.
Good luck.
Nov 08, 2010 | Cherokee Jeep Grand RB4 Navigation, AM/FM,...
Kenwood 6 disc player says no disc
Hi
The drive is not reading the disk properly. This is either caused by a fault in the laser/lens/drive itself which is leaving the laser misaligned and unable to read the disk or it is caused by dirt in the drive effecting the lens.
There is a Laser cleaning DVD that you can purchase from any audio shop - its not expensive and useful to have around anyway. I would recommend you try a good qulity one such as this from Maxell http://www.amazon.co.uk/Maxell-Europe-Ltd-CD340-Cleaner/dp/B000001OM5
You may find that this will resolve the problem as a simple and quick fix.
If the cleaning disk does not work then the unit will have to go for service repair
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 21, 2009 | Kenwood KDC-C467FM 6-Disc CD Changer
Dec 16, 2007 | Kenwood CD-223M 200-Disc CD Changer
NO DISK
What are you trying to check on the laser? Do you have a 'scope? There are also several types of infrared detectors out there that work well, but a 'scope is needed to ensure that the power level output is correct. Oh yeah, there is a detector that will plug into your DMM and read out the wattage...accordianman
Nov 28, 2007 | Kenwood CD-223M 200-Disc CD Changer
Mp3
you should clean the lens and adjust it....before change any piece....
Nov 24, 2007 | Kenwood CD-223M 200-Disc CD Changer
Kenwood CD-223M 200-Disc CD Changer Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
