Question about Canon LASER SHOT LBP-2900 Printer
I have got LBP2900B new printer, even after placing toner catridge and paper , its saying Paper Jam inside printer.. this is the first time,i am using the printer, please help
  • arunachal196 Apr 04, 2011
    thankyou very much, i will check the same
  • arunachal196 Apr 10, 2011
    problem solved....a sensor knob was broken, canon service person said., it would have happened during shipping..
  • 1,179 Answers
What you need to do is to remove the toner and ensure that the stickers that are to be removed are removed.
Also be sure to check that nothing is blocking the papers path through the printer.
Go through the instruction manual slowly, it may show you which stickers to remove.
damnor01
Posted on Apr 04, 2011
  • damnor01
    damnor01 Apr 06, 2011
    How did it go?
    damnor01
  • damnor01
    damnor01 Apr 12, 2011
    Would you be so kind as to rate my solution, thanking you damnor01
It says paper jam remove toner but there is no paper jam at all
Try power cycling the printer. Otherwise there is a paper jam or a sensor is dirty. Every time I hear someone say there is no paper jam I almost always find one. Use a flashlight they can be very very small.
Dec 18, 2012 | Office Equipment & Supplies
Paper has jammed rinter
paper jam is of two types.1.while spolling half paper will come out tom tray.remain jammed in rollers.This can solve by switching the printer power off and remove toner catridge from printer.Then power on the printer.lift the top rollers cover and reset as it is.The paper will come out without any difficult.2.Paper jam inside the toner catridge by rolling itself to drum.Switch off the printer power.Remove toner catridge from priter.Unscrew the toner catridge cover screws.remove drum from toner catridge .Utmost care should be taken while removing jammed paper from drum.Reassemble as it is and set.
mohanraojagan@yahoo.com
Nov 07, 2010 | Brother HL 5170DN Laser Printer
Printer cannon ip1500 says paper jam
just open the catridge cover and remove all the catrdiges and check is there any pices of paper is stuck inside.
Jan 21, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Paper feed is jamming ,I have not even gone through the original ink cartridges yet,so i haven`t done a lot printing
Things to do remove the papers jammed inside the printer.
  1. Please Turn off this Canon Pixma 2600 printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper or any piece of paper got trapped in the printer..
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Do it carefully with utmost care.
  8. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Before inserting the Toner or Catridge, please wipe the roller with cloth gently.
  10. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
See alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 16, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Paper jam
go over these steps:
alternative :
Mar 27, 2009 | HP LaserJet 5mp Printer
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
alternative :
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Paper Jam
try these steps
alternative :
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
Paper jam
hey, give this a shot
alternative :
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
My New ML-2010 creates a loud annoying sound!
Ok, it is good you checked for paper jams. I need you to look inside the unit where the paper roller is on both sides and see if both sides look even and the same. It still sounds like a jam to me, and this would definitely create a loud sound as your unit is trying to print for you and the mechanism will keep trying to turn even if it can't. Something may snap or break if there is a jam so make extra extra sure you check every nook and cranny as jams can be so very tiny. I found a piece the size of a matstick width in mine that my toddler had posted in it, and it was caught in the paper roller teeth inside the unit. When you open your printer, does the cartridge holder roll by itself to the left or stay still??? Take out the toner cartridge and thoroughly clean inside with solution and replace.
Aug 16, 2007 | Samsung ML 2010 Laser Printer
Canon LASER SHOT LBP-2900 Printer Logo
132 people viewed this question
old marine
old marine
