Question about Canon PIXMA MP530 All-In-One InkJet Printer
The alarm button is flashing and I am getting a message check printer. Not sure what to do.
  • 844 Answers
Welcome to FixYa!
"Check printer error" occurs if the printer is not functioning properly.
Solution 1.
Reset the printer to clear the memory.
  • On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  • Wait approximately ten seconds and then press the button again.
  • Wait until the device has completed its cycling process before using it again.
Solution 2.
Reset the print head to correct print issues or clear print error.
  • Confirm that the printer is powered on and press the button. (The paper output tray will open.)
*MP800R shown
  • Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  • Open the inner cover.
  • Remove the ink tanks by pressing the tab of each tank.
Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  • Raise the print head lock lever.
  • Tilt the print head slightly towards the front of the machine and lift out gently.
Caution: Do not touch the print head nozzles , electrical contacts , or ink supply ports . Doing so may cause printing problems.
  • Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  • Insert ink tanks into the print head.
  • Press the mark on the ink tank firmly until you hear a click.
  • Ensure that all the ink tanks are installed properly and the ink tank lamThe alarm button is flashing - jas247_64.gif
The ink tanks are installed properly.
The ink tanks are not installed properly.
Close the inner cover and the scanning unit (printer cover).
Note: The next printing begins, the print head cleaning will begin automatically.
I hope that this 2 solutions will resolve your printer problem.
Thank you for using FixYa.
Keep me posted.
Jas247
Posted on Apr 04, 2011
Error code 5100 displayed with orange alarm and green on off buttons flashing on and off
According to the manual, Error message 5100 indicates: "Movement of the FINE Cartridge Holder is blocked. Open the printer
and make sure there is no little piece of paper or other
object keeping it from moving. Unplug the printer.Then disconnect the printer f
from the computer. Plug it back in and try it again.
Aug 11, 2010 | Canon Office Equipment & Supplies
CHECK PRINTER (5800)
Please un and re install the device drivers following link
Installing Devices on PCs and Laptops
May 05, 2010 | Canon PIXMA MX310 All-In-One Printer
How fix E42 message?
An E42 is a scanner error. The most like solution is to reconnect the flat ribbon cable from scanner to motherboard of the MP150
Apr 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Alarm button Flashing, will not perform any function
Turn your printer on. On your computer, go to:
Start
Printers and Faxes (or Control Panel - Printers & faxes)
right click on your printer icon
click on "Printing Preferences"
in the dialog box, click on "Maintenance" tab
click on "View Printer Status"
in the dialog box, click on "Options"
then deselect the "Enable Status Monitor" option (remove check mark)
When the alarm light on the printer blinks and the printer won't do anything not even scan, you can press the reset button (on the printer) for 10 seconds and then, while holding the Reset button down, you simultaneously press the OK button (on the printer) for a few more seconds. For some reason, I sometimes need to do it several times before the alarm light goes off but so far, it always unblocked the printer in the end.
At that point, do the "Enable Status Monitor" as explained above. (put check mark back)
When you need to check the levels, you can either look at the cartridges physically or enable the status monitor (if you are still using 'legal' cartridges in one or more slots).
Google for "Chip resetter for MP530" or go on Ebay for this product.
Jan 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
CANON MP210 ERROR E15 - INK NEW PRINTER, NEW INK
Go to this link. In the search window in the center of the screen, type "error e 1 5" and click on the Search button. Select the appropriate error message, then select the answer that says "reseat ink cartridge". You may not have locked the cartridges into place by lifting up until they click.
Oct 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Alarm light flashing, please wait message
Can only try
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Error U163
Press and hold the 'Reset' button down for 5 + seconds.
Jun 04, 2008 | Canon MX300 Office All-In-One Printer
ALARM!
make sure printer connect to power source/cable power then
press power button while press stop button,release stop button while still press power button.
press stop button twice and release.
after power button stop blink press stop/resume four times then turn off printer.
Mar 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
