OUR FUJITSU AC UNIT MOD NO AOTRO9LCC LIGHTS FLASH RED/GREEN.....RED/GREEN....RED.....RED....RED....RED....RED WHAT IS WRONG?
5 Suggested Answers
  • 81 Answers
SOURCE: fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps. http://www.oceanairdist.co.uk/assets/pdf/service/Fujitsu/ASYA09LC.pdf
Mat
Posted on Jul 16, 2009
hvac1960
  • 2133 Answers
SOURCE: both red and green lights blink together on the
Blower motor mechanism locked and hence the unit couldn't start. Repair/replace fanmotor.
Posted on Dec 13, 2010
hvac1960
  • 2133 Answers
SOURCE: Hi there, we have a
Indoor coil thermistor is short. Replace it. It's located in indoor coil ending with copper sealed tub. Thanks.
Posted on Feb 02, 2011
SOURCE: Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Posted on Oct 28, 2011
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
I have a Fujitsu ASU24CL1 and after a loss of power we now have no A/C. Fan works but the red and green lights flash 5 times then go off for a short time then flashes again ?
Seems like a problem with ur condenser power wiring, check diconnect, line from breaker should be in line and line goin to cond should be on load
Jul 01, 2012 | Fujitsu 24C1 Air Conditioner
Both red and green lights blink together on the fascia on the Fujitsu inverter unit
Dec 13, 2010 | Fujitsu Heating & Cooling
Fujitsu asya09lcc wallmount split lights flashing indoors
Mat
Jul 04, 2009 | Fujitsu 24R1 Air Conditioner
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
Flashing lights?
Hi there
This sounds like a faulty Powersupply.
Before replacing it , try replacing the fuse on the board first.
Apr 14, 2008 | Fujitsu LPF 7200 Multimedia Projector
Bluapunkt CDC IDC A09
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Feb 29, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Heating & Cooling Logo
90 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
