Question about Biostar TA790GX A3+ Motherboard w/ AMD Phenom II X4 965 CPU Bundle (TA790GXA3+PII965BUNDLE)
Hi, I have an problem with installing XP Pro oem after first part of install when it reboots it shuts down got with my mb 2 Patriot Viper 4Gb (2 x 2Gb) 240pin DDR3 SDRAM DDR4 1333 (PC3 10666) Dual channal kit desktop model PVS34G1333ELK. i tried first to install XP tho with this only it shuts down. Any suggestions?
  • Biostar Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 04, 2011
VGA problem
plz dont use vista !
use xp for game performance ...ur vga driver may not have the ability to install
so use xp
thank u.....
Aug 06, 2009 | Viper Diamond ATI X1600 PRO AGP 512MB...
Can't install OEM Windows XP on fresh hard disk
please check the consistancy of hard drive or try to run a zero format first and then reinstall the win
Apr 15, 2009 | Computers & Internet
Replacing mb hdd, can i still reactivate xp pro?
You should be able to
May have to phone microsoft to do so if you do have pen and paper handy to write numbers (a lot of them down)
Oct 30, 2008 | Intel Motherboard
IBM Blue Screen
I had the same problem with an Intellistation 6868 for years. It just wouldn't load XP but ran fine on Windows 2000 SP4. I tried 3 different XP Installation CD's with no luck. After several attempts at installing XP I bought a clean XP Upgrade from ebay.
It took me 3 goes to install it but eventually I got it in there. If you can get XP to start on the 6868 press F8 and start it in safe mode first then when it's booted fully, shut it down and and then start it clean again. It worked for me. I've been running it for 5 months now and it's fine.
I couldn't get it to work at all on the 6868's onboard IDE so I installed a PCI Raid Card and it boots fine on that.
System:
IBM 6868 52A M-Pro Intellistation
2 x Intel P3 866 CPU's 256 mb cache
2 GB ECC RD Ram
2 x Seagate 320 GB 8MB Cache HDD on a Sunix ATA133 PCI Raid Card
2 x Seagate 10000 rpm SCSI HDD on Adaptec Raid Card
ATI 9520 AGP 128mb Graphics
Win2000 Professional SP4 - Upgraded to XP Professional Edition SP3
Dual Boots with Xandros Linux Desktop Destop 3.01C
Sep 08, 2008 | IBM IntelliStation M Pro 6868 PC Desktop
Samsung v25 shutdown
hi dear
Do not complete the following procedure unless you are very familiar with internal computer hardware removal and installation. The hardware components in a computer are very sensitive to static electricity. For information about the correct handling of computer components, contact your computer manufacturer. 1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices. 2. Restart your computer. • If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices. • If Windows does not start successfully, remove one or more of the memory modules that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Note Windows XP requires 128 megabytes (MB) RAM. The minimum is 64 MB and the maximum is 4 gigabytes (GB).
For example, if two 256-MB memory modules are installed in your computer, remove one of the memory modules. If Windows starts successfully, shut down the computer, and then reinstall the RAM modules one at a time. Start Windows after the installation of each RAM module. When you install a module that causes the issue that is described in the "Symptoms" section, remove that module, and then continue to install the other RAM modules. 3. Determine if the PCI devices in your computer are compatible with Windows XP. To do this, visit the following Microsoft Hardware Compatibility List (HCL) Web site: http://www.microsoft.com/whdc/hcl/default.mspx
Mar 22, 2008 | Samsung V25 XVC 2800 Notebook
Screen shut down
hi furotte,
u have taken a right decision u havt to buy a new graphic cards while buying card just read the manual of cod4 it shows the latest graphics that supports the manual will be in cod4 game file
regards
shailesh
Mar 12, 2008 | ASUS EAX1950PRO/HTDP RADEON X1950 Pro,...
Motherboard
check ur BIOS setting.. set the default BIOS setting n try installing with another windows CD.. I hope if ur HD is gud thn It'll work.. BEST of LUCK!
Feb 14, 2008 | ASUS A8N-E Motherboard
US-144 on Windows XP home giving problems
Hi
Try Winxp Pro, if it doesn't work then do upgrades one by one to avoid spending too much, increase the memory, the harddisk and the video card...
It needs a lot of space for recording, a lot of memory for processing before saving, and the video card to improve performance of the computer.
Goodluck !!!
Feb 02, 2008 | Tascam US-144 Sound Card
Installing windows xp with 2 new sata wd 150g 10k 16m raptors to NO avail...
I guess you are trying to install Windows XP in RAID 0 configuration. If so, you need to do several steps:
1. Configure the bios to work as RAID 0
2. Download the RAID driver from the mobo vendor site, copy it onto a floppy disk and have it ready for when Windows asks for it.
See this link for detailed example http://www.duxcw.com/digest/Howto/mb/abit/kx7-333/raid1.htm
In SATA there is no master/slave configuration, so there is no need for jumpers.
I hope this answers your question.
Dec 26, 2007 | Western Digital (WD1500ADFD) 150 GB Hard...
Biostar TA790GX A3+ Motherboard w/ AMD Phenom II X4 965 CPU Bundle (TA790GXA3+PII965BUNDLE) Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
