Question about Toshiba Satellite A105-S4334 Notebook
Black screen my computer just went out black screen, after rebooting numerous times, it will power on the blue on light is lit on power, electric, and battery on. complete black screen, left off overnight with no luck next day.
  • 3 more comments
  • darlene p Aug 05, 2008
    black - compeltely black. exactly as if when computer is switched off.
    toshiba laptop a105-s4334, screen appears as if off, is the lcd out?
  • darlene p Aug 06, 2008
    I connected it to another working monitor still no main screen comes on
  • jslschatz729 Aug 16, 2008
    i went to toshiba assist then i clicked the secure and type a password at the supervisor after that it said that it needs to turn off to activate then when i click the yes button and restart it again. then the screen went black already but there is power ,pls help
  • Karthik P May 11, 2010
    what do you mean by black screen ?
    is it completely black or blank ?
    blank - backlight would be On. This is similar to the "blank" screensaver. you might be able to see lights on the edges of the screen.
    black - compeltely black. similar to when computer is switched off.
    P.S. is it laptop or desktop ?
  • 4 Answers
I had the same prob first get a flash light can you still see the windows? if yes then you have a faulty lcd backlight inverter board. same thing happend to me first i changed the lcd cause it had bleeding horizantal lines. so i know the screen was bad then it worked fine but then the screen stared to black after a few minute alternat 5 or 10 minutes then it never came back so i did reaserch and decided to replace the lcd back light inverter board about 49 dollars brand new then i replaced itt and walla perfect.
Posted on Feb 11, 2009
    Sergeant:
    Champion:
  • 435 Answers
Did you leave it connected to external monitor for sometime.?
coz, external monitor does not come up until the computer gets to the login screen.
Do you see any activity on harddisk light when switched on ?
If not, the problem is with the board.
Posted on Aug 06, 2008
    Genius:
  • 1,056 Answers
One way to test it is to connect a monitor to the VGA port (make sure to activate the external monitor (Fn+monitor key)
If it does work on the external monitor, I would look at replacing the onboard LCD.
If it doesn't, you are looking at problems with the onbaord video.
Posted on Aug 05, 2008
What would cause my screen to go black and then can't reboot 8.1 on dell pc??
If this is a Laptop, remove battery, Plug in charger to PC and then try to reboot. A bad battery will suck all the power from charger and won't allow the computer to have enough power to boot.
Aug 18, 2014 | Computers & Internet
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
Nov 08, 2012 | HP w1907 LCD Monitor
I have an MSI Wind U100 which was powered down without any drama but the next day when it switched on, the screen remained black and only the blue power light plus the Wifi and bluetooth indicators...
It is likely that the backlight went out on the screen. This model has an LED backlight and can be replaced. If you are mechanically inclined, you can purchase a new one on ebay or amazon and replace. If this is a motherboard problem, then it is likely not worth fixing. One way to tell is to see if the screen is completely black. To test, turn on the computer and go near a bright light source. if you can barely make out any image on the screen, then the LED backlight is bad. If the screen is as dark as it is when the computer is off, then it is likely the motherboard.
Apr 17, 2011 | Intel Motherboard
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
MX6448 won't boot; black screen.
It seems that you don't remove the battery when you use the Notebook. This practice shortens the life of the battery because, when you use the a/c adapter and the battery, your battery is alternately charging and discharging all the time. The cells in the battery eventually die.
From what you describe, it sounds like the power strip inside the Notebook (where you plug in the adapter cord) has been damaged and needs to be replaced.
Your computer is not a total loss. Just have that power strip and the battery replaced and your Notebook should be up and running again.
And, in the future, if you just remove the battery when your kid uses the computer, or if you are going to be using it for over 1 hour. Save the battery to use when you need the mobility.
Oct 10, 2009 | Gateway MX6448 Notebook
We went to use our Toshiba L305D laptop. All lights are lit, but nothing shows on screen. Hold in power button to restart and computer sounds like it's rebooting. Screen is totally blank.
try to remove the battery fact then open it.. if the same problem..
check the inverter of your pc.. try ot use safe mode. restart your computer then press f8 select safe mode
Jun 25, 2009 | Toshiba Satellite L305D-S5904 Laptop
Computer won't start
The power supply is fried partially, or the motherboard went poof.
Dec 19, 2008 | Antec TruePower 2.0 550W 24/20pin nVidia...
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Screen went black
Hi, could be anything to do with video. Might be the on board video card or its memory. It is also possible that your display lost its back lite and you just can see the display. Try turning the laptop on normally and let it run for a while. Try tilting the display left right up down as if trying to gaze at the inside of the display. If you can see faint traces of your desktop then it is definitely the back lite, if none then something else is at fault. Either way you will have to bring it back for repairs or replacement. You can also try checking the memory by sliding out the panel cover at the bottom of the casing. There might be a screw or two locking the cover panel in place. Try wiggling the memory a bit, might have loosen up somehow. If still a no go, then perhaps you're really better off sending it back for repairs/replacement. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Jul 29, 2007 | Acer Aspire 3680 Laptop
Toshiba Satellite A105-S4334 Notebook Logo
305 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
