My monitor keeps going black with everything squashed into a narrow horizontal band in the middle of the screen. Monitor is fairly old do I need a new one? If I turn the monitor off and on again it comes back as normal.
How can I adjust the screen resolution?
select menu > wide, then select wide or zoom.
some TV channels add black bars to the picture.
Apr 12, 2013 | HP Compaq Presario FP7317 17" LCD Monitor
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
Screen shrinks down to a narrow band of light in
You have bad grounds on the vertical IC. The grounds will need resoldering and check for weak caps near the ic.....they will overheat the ic...creating the bad grounds. Solder will expand and contract with heat and cooling of a tv. HMMMM you could also have a cold solder elsewhere on the board. Search and you shall find.
Aug 16, 2009 | Televison & Video
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
Monitor fails to adjust-narrow in the middle
You have to use the OSD (onscreen display) to adjust the vertical height or the horizontal width.
If you have an auto button, try letting it readjust your monitor to the default setting. If this doesn't work, find the geometry setting and adjust the hoizontal or vertical manually to correct the "narrowness".
If this doesn't help, please reply with your monitor make and model number and we'll see if we can sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Computers & Internet
Suddenly my horizontal size on my Dell montoris reduced about 1/3
On the monitor there should be some buttons that allow you to manually configure the width and hieght that the screen comes up with.
Does you screen come up squashed but you can still see everything or only 1/3 of the screen is shown and the rest is black.
Mar 20, 2009 | Dell E153FP 15" LCD Monitor
Apple 30 inch monitor
No, this is not normal. This could be one of two problems. 1) internal connection to the "Y" array is somehow been compromised either through some defect in manufacturing or simply a loose connection. 2) The LCD converter board in the monitor is defective. In either case it's internal to the monitor and would have to be serviced. Have you checked with HP to see if the device is still under warranty? It just might be If not, you can try opening the unit and checking the connection on the left hand side towards the area you mentioned. But beware that the monitor does contain leatal voltages.
Nov 20, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor goes black with a white horizontal line across the middle of the screen
Check to see that the monitor cable is correctly installed. Also, make sure you have the most up-to-date drivers installed for your graphics adaptor card(both ATI and Nvidia carry catch-all driver programs to keep you up to date.) Tighten the cable screws of course, to make sure the monitor cable isnt just wiggling in its seating.
Jun 05, 2007 | LG Studioworks 900B 19" CRT Monitor
Sounds like a possible bad pixel. I would power the machine down, reseat the graphics card, reconnect the dvi link, and reset the PRAM.
Keep me posted.
Nov 14, 2006 | Apple Cinema HD 30" LCD Monitor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
