Question about YouTube Videos
How do I go about getting on to U tube - YouTube Videos
    Novelist:
  • 153 Answers
In order to go to Youtube website, you open your internet browser and type the URL below to the Address field.
http://www.youtube.com
Regards
Posted on Apr 04, 2011
Water spews out of the tube in back of ref while water is being dispensed from front
It sound like the plastic tube is cracked at the valve. After a while the tubing gets brittle and cracks. This is usually easily fixed by getting a quick connect plastic tubing couple and some tubing in the size of the tubing that cracked.
Sep 26, 2014 | Refrigerators
Error f1
The f-1 can be caused by a faulty control, a hole in the tub to control tubing, tubing fell off the control, or junk in the base of the tub blocking the tubing. Before buying a new control blow through the tubing to get the sediment out of the base and make sure the tubing is secure. Now here is a video which shows how to swap out the tubing:
Sep 14, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Which is better to get - manual focus or AF extention tubes for Nikon D3100
AF tubes will let you focus manually, so you don't lose anything by getting AF tubes (except for additional money, perhaps). However, most close-up work requires manual focus anyway due it the very limited depth of field, so you won't gain much by getting AF tubes.
Personally, I've never missed the AF capability when using my manual tubes with my Nikons.
Jun 18, 2012 | Opteka Af Macro Extension Tubes For Nikon...
People are having difficulty hearing me
It could be that the voice tube is dirty. Sometimes just getting a sugary drink in the tube will leave crystals that can block your voice. If there is food in there, it will definitely block your voice. A couple of solutions, you can try washing and rinsing the voice tube with warm soapy water. The voice tube must be completely dry before trying to use again. And sometimes you just need to replace the tube.
Here is a link to the right voice tube, if you wanted to purchase one:
Plantronics Voice Tube #29960-01
Good luck from Headsets Direct!
Dec 06, 2011 | Plantronics TriStar H81 Headset
My estate whirlpool washer model# taws800jq1 water wont shut off when you start cycle
See this tubing:
If this tubing gets sediment in it OR vibrates loose OR gets pinched from re-installing the cabinet OR if the tube gets a hole in it then the pressure won't build up as the water level rises and the water will not shut down. The component that tube is attached to it the water level switch. The likelihood of it being bad is slim. Most of the time sand and sediment gets into the tubing and simply blowing it out and reattaching the the tube to the switch fixes it. Be sure to pump out water after cleaning and re attaching the tube to the water level switch. Service manual and more
Nov 08, 2011 | Estate TAWS800JQ Top Load Washer
I just got a used deep freeze.. but i was told something was wrong with the copper tubing.. it needs to be replaced.. what does this copper tube do? and relatively how much could it cost?
if the copper tube needs to be replaced then that means it is now worth fixing. the copper tube is what the refrigerant runs through. no copper tube - no refrigeration. Also you would have to fully destroy the fridge to get to the tube anyway. You may as well get rid of it. sorry
koolman77 (refrigeration technician)
Feb 07, 2011 | Refrigerators
My 2005 Equinox has a broken EGR tube, I need to get a replacement tube. Can you please get me the part number?
My tube broke several years ago. The original tube is longer than the replacement. Evidently the GM was unable to make a long tube that would not break. You have a long tube if the input of the EGR (where the tube connects) is higher than the output (where the EGR connects to the intake manifold). If you have the longer tube, you must purchase a replacement from GM which is $200 and includes the short tube, new design EGR valve and a new connector to replace the old EGR electrical connector.
Nov 07, 2010 | 2005 Chevrolet Equinox
I have new Accent Excutive car, i just notiec that my car tyer type is Bridgestone S322 . My Question is its a Tube less tyre ? My car has all company fited tryes one of them show 175/170 R 13-...
putting a tube inside a tubeless tyre is a cheap way of fixing a puncture,BUT DO NOT EXCEED 75MPH,as, if the tube gets punctured,you could lose total control of the car......If you get a puncture with A TUBELESS TYRE YOU SHOULD ALWAYS replace it (how much is your life worth)Tyres have written on the wall wether they are tubeless or not.DO NOT MIX THEM,lastly NO MANUFACTURER fits tyres with tubes for road use.
Oct 18, 2010 | 2009 Hyundai Accent
I need to replace a 16.125 tube with a 16" bell universal tube. The universal tube appears to be too large for the rim and the website is under construction where I should be getting the insructions.
the 16"tube cant possibly be too big to replace a 16.125 tube unless it was the wrong tube to begin with,check the tire to see if the proper tube size is located on it
Jun 01, 2010 | Bell Sports Bell Universal Bicycle Inner...
YouTube Videos Logo
189 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
