Wharfedale dvdr24f. this is my second q on this. Initially it was not recording anything which was correctly diagnosed as being a faulty connection. Now its coing up with messages VRseq error and problem loading check connection. I'mm guessing this is the same thing, is it merely a case of trying different scarts or could the connection issue be elsewhere. thanks
  • johnnylate Apr 09, 2011
    hi, and thanks, apologies for not getting to this sooner, 2 small children etc etc.
    to be fair to wharfedale the factory reset is in the manual, but it doesn't seem to have changed anything.
    I'm not geting the errors anymore but the basic problem persists, it looks like its recording but there's nothing on the disc afterwards. Its been suggested that the issue is with the connection between the sky+ and the dvd recorder. I've tried the scarts elsewhere and they seem to work, so could it be the sockets? Given the cheapness of the kit the hassle is starting to outweigh the value of trying to make it work.
    Genius:
  • 1,622 Answers
Hi,i will give you factory reset guide try it and if it does not work,that means it'sthe same fault..contac your repairer for help..
This solution may work for other Wharfedale DVD recorders as well as the DVDRHD400F.
Use your Setup button to access the 'Setup' menu.
Choose the 'Preferences' menu.
Choose 'Factory Defaults' and click on 'OK'.
The recorder will restore the factory defaults and the first screen it takes you too is the 'Initial Setup' screen where it asks you to enter the correct date and time.
May work on similar DVD recorders. Would help if Wharfedale included this in their users manual.
Hope this of use
Posted on Apr 04, 2011
Wharfedale power board dvdr24f
the fuse may have blown in the plug or it may be a fuse in side ?.
Sep 15, 2013 | Samsung SIR-TS160 DirecTV DTV Receiver
Did anyone fnd a solution to this... 'My wharfedale DVDR24F has stoppped recording-My machine has worked great up till now but it suddenly stopped recording. The blue light is on saying that it is but then...
Recheck ur unit wiring for a lose or damages wiring connections between the DVD recoder player and the tv.This problems,u tries many recodering,have same result?Yes,than 100% u have wiring problems issues.
Apr 03, 2011 | Televison & Video
Wharfedale DVDR24F showing E1000 error. Can this be solved
Mine did this it was the a capacitor on the Power Supply Board. C112, it is an Electrolytic 2200uF 16v.
Feb 08, 2010 | Samsung SIR-TS160 DirecTV DTV Receiver
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
What are the correct connections for a wharfedale 80GB hard disk drive with freeview to a wharfedale digital TV with freeview and a dawoe video recorder?
Hey matt here, From memory I think it tv- video via scart and then scart or avr to HD. Hope this helps. Matt. Please Rate me
Dec 31, 2008 | Televison & Video
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Setting the clock on a Wharfedale DVDRHD400F
Try scanning for channels. It may well download time and date automatically.
Dec 21, 2007 | Wharfedale DVD-M3 DVD Player
About Wharfedale Tv
have 20" warfdale lcd tv cannot tune to samsung dvd recorder
any help recieved
Sep 02, 2007 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Electro Med Services...
