Question about Samsung Cell Phones
My mobile was high heat when operate this model no isgtc3200
    Problem Solver:
  • 16 Answers
Hi There,
After doing a couple of searching, i found a site wherein samsung phones do really heat up evern when placing it in a place where heat is low. I advice to have your battery checked for short circuit problems before it also damages your cellphone unit.
Posted on Apr 04, 2011
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
Atwood 1522 LP furnace fan operates at one speed only
Furnace only works at one speed, high and low fan is usually used for AC. It never has had 2 speeds on furnace correct? Furnaces usually only have 1 speed, except for some home models.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
I am installing a heat pump, and i having 8 flashes at my green LED .
look at page 17 here is all the install instructions plus troubleshooting
x air conditioner/heat pump
operates at reduced
performance.
x Air conditioner/heat pump
operating at low stage when
expected to operate at high
stage.
x Integrated control module
diagnostic/status LED's display
the indicated code
http://www.alpinehomeair.com/related/IO-348K%208.2013.pdf
Oct 06, 2013 | Goodman Manufacturing Goodman DSZC160601...
Not be how to operate this thermostat
That is a high/low model. The one on the left is the low and the right is the high. So if you use ac/heating, set them according to what you want to achieve.
Oct 08, 2012 | Heating & Cooling
Heller ptc55 will not operate on high heat
test the heating element 2) test the switch selector for open or dirty or defective
Jun 19, 2012 | Dishwashers
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
Hiii am using nokia e5 model..now and i have downloaded e buddy mob messenge to my mobile...for that..its asking for java applications..can u please tall me how to activate java to my mobile
All the models of the Nokia are very popular on their season. Some mobiles are actually record breaking as well, the accessories which company uses are of a very rich quality and at a high standard. Especially the model of the company Nokia 800 is a internet tablet, that was launched and presented at the place of Las Vegas CES 2007 and summit in January 2007, that was a brilliant model for all the users, there are also many other good models like Nokia C2_200, C2_01, and lot more.
Jul 16, 2011 | Computers & Internet
How can download of flash player
Adobe Flash Player is the high performance, lightweight, highly expressive client runtime that delivers powerful and consistent user experiences across major operating systems, browsers, mobile phones and devices. Specific versions are available for Internet Explorer and other browsers.
d5.gif Flash Player 10.2.152.32 (IE)
d5.gif Flash Player 10.2.152.32 (Non-IE)
Mar 07, 2011 | Echo 001107 Power Blower Helper Handle...
NO HEAT
The electric dryer heating circuit is composed of the heating element, high-limit thermostat, thermal cut-off, cycling thermostat, timer, and centrifugal switch. Parts may vary depending on the make and model of the dryer; specify it for a more specific advice. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The dryer will not heat when any of its components has failed. Check the continuity of the high-limit thermostat, thermal cut-off, cycling thermostat and the resistance of the heating element using a volt-ohmmeter. The heating element has a resistance range of 8 ohms to 12 ohms depending on the make and model of the dryer while the other three components must have zero resistances.
The timer and the centrifugal switch are less likely to cause a no heat problem and must only be checked when the components mentioned above are found to be in operating condition.
Again, specify the make and model of the dryer for a more specific advice.
Apr 11, 2010 | Dryers
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Cell Phones Logo
24 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
