Question about Bosch Logixx WFR 3267 Front Load Washer
Childproof lock in our laundry machine model logixx 8 is activated and i cant turn it off
    Guru:
  • 500 Answers
Hold the Start/Pause button for 8-10 Seconds.
This usually does the trick.
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 04, 2011
Its Bosch washing machine..how to unlocked the childproof locked?
My earlier post to you showed you how. Look at the videos, read the text. The very first video was Bosch
Bosch Laundry Child lock function - YouTube
? 0:14
https://www.youtube.com/watch?v=q8tyjUDiIBE
Jun 12, 2014 - Uploaded by OrigoIreland
This video is about the Child lock function in Bosch laundry range. Origo represents Bosch in Ireland ...
How To: activate and de activate child lock on your bosch ... - YouTube
? 2:25
https://www.youtube.com/watch?v=JdHTUq9qZRs
Feb 29, 2016 - Uploaded by Nadidoh Ripoya
hi people on youtube, and i am showing here how to activate and de-activate child lock on the bosch logixx ...
? 2:30
https://www.youtube.com/watch?v=-gFGfYA5EA4
Jun 12, 2016 - Uploaded by Ezrak Buldan
Bosch washing machine how to unlock the childproof lock Google Search
Nov 08, 2017 | Bosch Washing Machines
Bosch avantixx 8 waq error code e44
E44 means a motor fault. More here: http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes.html
Mar 03, 2015 | Bosch Washing Machines
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
My dryer drct70w will not power up have check on/off switch and fuse they are working ok none of the lights illumiate
Machine does not switch on or the programme does not start. Machine is not activated when set.
* It might have not been plugged in.
* The loading door may be ajar.
* Programme might have not been set or the «Start/Pause/Cancel» button might have not been pressed.
* «Childproof lock» might have been activated.
* The condenser cover on the models with a condenser might not be closed securely.
* Make sure that the machine is plugged in.
* Make sure that the loading door is properly closed.
* Make sure that the programme has been set and it is not in "Pause" mode.
* Deactivate the childproof lock.
* Make sure that the condenser cover and the red lock is closed securely.
A Call an authorised service agent if the problem persists.
Dec 02, 2014 | Dryers
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
My Logixx 8 washing machine is stuck at error code F:23. What is that waiting for ?
Unfortunately it is waiting for an engineer to investigate 'flooded base s/w activated' which is what the Bosch Logixx F23 stands for ;-0(
Sorry.
John C
Mar 19, 2011 | Washing Machines
Logixx 8, child lock wont come off
Hold the 'OPTIONS' button for 5 seconds
Jul 10, 2009 | Bosch Washing Machines
Childproof Lock
Hello mine is a WM14S79BUK but i think it works on most recent models with lcd display.
I have to hold the down button on the option buttons for 5 seconds to activate child lock or unlock
it's worth A TRY
Hope this helps
Jun 07, 2007 | Siemens WIQ1433 Front Load Washer
Bosch Logixx WFR 3267 Front Load Washer Logo
1,419 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
