Question about HP Compaq d530 SFF PC Desktop
3 long beeps before when booting - HP Compaq d530 SFF PC Desktop
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 332 Answers
I am sending you a link that tells you what your beep code is. You can compare it to the beep code you are getting. Print out and keep it for future use. Here is the link:
http://www.computerhope.com/beep.htm
I hope this helps you out and if it does please leave me some feedback.
Posted on Apr 04, 2011
Booting beeps
Beeping indicates that something on the circuit board is not working. On desktops beeping with no boot means your mobo is fried. And you'll need an expert to repair it, usually the vendor.
Jul 24, 2014 | Compaq Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Acer 5742g Beep at boot up
I have a problem that looks like this one.
At boot up, after the POST, each time the HDD led blinks, the laptop produces a loud "beep", and refuses to boot, as if this phenomenon prevented the HDD to be read.
If I press the power button, it stops beeping. When I release it, it starts beeping again.
If I press F8 at the beginning and then ask for a normal boot, It boots normally. Anyway, in windows, I have some strange activity, like I would continually pressing Alt+Tab. If I press Esc, it stops immediately and then all seems to work fine.
Any clue?
Jul 26, 2012 | Acer Aspire 5742G
Keeps beeping when on
Beeps and blinking lights tell the technician what is wrong with the computer. Count the beeps and the pattern of the beeps (3 long beeps, 1 long beep followed by 2 short beeps, etc).
Most times it's something related to the motherboard such as memory or video card.
Did you see anything post on the screen during the boot process?
Check your memory.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 09, 2012 | Acer Aspire 5536-5224 Notebook
Long beeps at startup and won't boot up
What is the pattern of the long beeps? one long beep or two long beeps, three long beeps?
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Mar 29, 2012 | Computers & Internet
How to stop the beeping sound
Beeping sounds when you try to boot up? Is your system booting up all the way? Beep sounds help the technician isolate the problem with your computer booting. Beep sounds normally indicate a problem with the memory, cpu, keyboard, fan, motherboard, etc. The number of beeps can be looked up based on the motherboard brand or bios and it will tell what the problem is.
Mar 18, 2012 | Dell Computers & Internet
My apple macbook won't start and continuously keeps on giving a beep sound.
the beep pre-boot is signaling a kernel panic. It could be bad ram or something else, it's hard to tell without hearing the beep (they signify different things)
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
taken from http://www.welovemacs.com/whdoallthbme.html
So depending on the beep, it means different things. However in any case I'd suggest taking it to an Apple Authorized Repair Facility. Unless you feel comfortable with assessing the proper solution on your own
Good Luck.
Feb 17, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computer dead and beeping
If it beeps and not boot then it is the post routine telling you there is a problem. The post routine is run when you turn the power on to ensure the computer hardware is ok to run. The manufacturer of the bios routine can tell what is wrong by the type, number and duration of the beeps. Look up the code meanings and it will indicate the problem. If this sounds like nonsense to you then give the make and model of your machine and what the beeps sound like. ( beep beep beep delay beep beep beep) etc. and I'll look it up for you.
Aug 10, 2009 | Computers & Internet
Booting problem
One beep is normal during the boot process.
Apr 18, 2008 | Computers & Internet
HP Compaq d530 SFF PC Desktop Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
