We have this temp control in the house. How do we use it effectively?
    Scholar:
  • 133 Answers
Can you please provide more information? Roger
Posted on Apr 04, 2011
What is the low pressure for a 410a 3 1/2 York when is 90temp at fh outside.
The outside ambient temp has little effect on the suction pressure. The indoor temp is what will slightly effect the suction pressure. In the trade we say we want a 40 degree evap coil, this means approximately 125psi. This is when the indoor temp is around 74 to 78 degrees. The hotter the house, the higher the pressure. I like to see a 50 degree evaporator when the indoor temp is above 80. Charging by subcooling is the way to go!!
Sep 21, 2017 | Heating & Cooling
What is the effect of greenhouse
Greenhouse effect is where atmosphere reflects heat back instead of letting it escape.causing abnormally hi temps and condensation as a green house does.
May 15, 2017 | Garden
Heat temp gauge on motor if faulty can it effect the cooling temp of the air conditioning on a saab 93 convertible 2002 model
No. The engine temp sensor affects engine idle speed, and timing. There is an in car temp sensor that controls the position of the blend door and the fan speed if the system has automatic temperature control.It also cycles the AC compressor clutch and the radiator cooling fans.
Dec 22, 2016 | 2002 Saab 9-5
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
My 2004 Trailblazer is not starting every time. Sometimes it takes up to 5 tries to start. The codes I'm getting are P0106, P0420, P0410, &P0128. I'm on a budget so fixing them all at o
i have a 1997 blazer with the 4.3 and right now i have the ecm temp sensor unplugged. this does effect the way it starts in the cold. this particular sensor is on the front of the intake in front of the thermostat housing. this also effects the shift timing as well.
Oct 11, 2012 | 2004 Chevrolet TrailBlazer
Oven temp. will not go higher than 240 Degrees
Most ovens are preset from the factory. They are usually off a few degrees. This varies from house to house depending on the exact voltage in our home. This has an effect on how the control board reads the temperature sensor. This will require you to dial in the temperature to match the display on the control. Most ovens can be calibrated. You will find the instructions in your owner's manual if this is available for your model. If you do not have a manual, go to the bottom of the page and click on the link that says owner's manuals. They are free to download.
Feb 25, 2011 | Kitchen Ranges
My round Honeywell T-87 on the main floor(middle) of the house has no ON/OFF switch. It controls the temp of that level of the house and even though it is set at 60, the temp is way too high and reads 74....
What you are describing is the Heat Anticipator. It is a small resistor that helps the thermostat from overshooting the set temperature by heating up and shutting off the thermostat just before your set temperature. I don't think that is related to your over heat. 14 degrees is a lot and the Heat Anticipator will only effect it 4 or 5 degrees. I would remove the thermostat and check if there is a call for heat. If so, you have a shorted wire. If not, replace the thermostat.
Dec 30, 2009 | Honeywell Programmable Thermostat Heater
Temp sender
If it's like my 98 cavalier it's located in the housing where the upper radiator goes into engine, it's right beside it.
Sep 06, 2009 | 1996 Chevrolet Cavalier
Wrong temp. on the thermostat.
sometimes a power outage or a static spark will effect the stat, remove the stat from the wall take out the batteries and walk away from it for at least 10 minutes, then reinstall it
Aug 03, 2009 | Heating & Cooling
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
