Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Hitachi Plasma - green dots
I found you have the same problem as I with the green dots dancing on the Hitachi tv. Were you able to fix your problem and if so was it expensive? I notice the answer that is posted on this site appears to be a quick and somewhat inexpensive solution. Just wondering if it worked for you.
Thanks for your help.
Tanya McKinney
    Scholar:
  • 50 Answers
Please read all the info before you start and if you have any question please feel free to message me at pleasefixitdave@yahoo.com or just give me a call @ Cell # 1-503-432-9904 Ask for Dave! What you'll need to do is remove the stand and the back cover. Once you have both the back cover and stand off you'll need to put the stand back on the TV so that you will be able to set the TV up right! Then you will need to locate the Y sustain board. The Y sustain board is the board that is to the left side of the TV if you are looking at the TV from the back side. The Y sustain will have a large heat sink on it 3 1/4 inch's wide and 6 inch's long. There is a small heat sink 3/4's of an inch wide and 3 1/2 inch's long just above the large heat sink. A little to the right of the larger heat sink. The little heat sink also has two large capacitors just to the left of it. Once you have located the small heat sink you will want to look just to the right of it and you'll see two Blue with Yellow centers adjusters.Hitachi Plasma - green dots - b5e4dcb.jpg You do not want to touch any of the adjusters other then the two that has the location #'s VR1 & VR2 next to them. Please make sure you have located the right adjusters by making sure that the location # next to them is VR1 & VR2. Start with adjuster VR1. Before you make any ajustments take a felt tip pen and make a stright thin line over the top of the Blue with yellow center adjusters. This will help you put the adjuster back in to the factory setting position if you need to start over and it will also give you an ideal as to how much you have adjusted the adjuster. At this point you should have the TV with the back cover off and the TV in the up right position with the stand on the TV. Now you will need to find a friend to watch the screen while you make the adjustment to Location # VR1 & VR2. plug in the TV and turn it on. The TV should be cold, another words if you have had the TV on at all let the TV cool down for about an hour or so before you do the adjustment. Start the adjustment by turning VR1 counter clock wise slowly untill the specs on you screen go way. If the specs on you screen get worse then put the adjuster back in the factory set position and turn the adjuster VR1 clock wise until the specs go away or lessen. In some cases you will not be able to get ride of all the specs but you will be able to lessen the amount of Green or Red specs on the screen. If adjusting VR1 dose not completely clear all the Red or Green pixels from your screen make the same adjustments to VR2! WARNING: Plasma televisions use high voltages to display images on the screen. Be sure to unplug your unit, and then press the power button on the front panel to discharge the capacitors in the unit before beginning to open up the case. Always observe the necessary precautions when working around electrical equipment and never touch anything with your bare hands that may be carrying a stray voltage. By following these instructions you agree to assume all risks involved with the repair of your unit, and agree to hold me harmless of any damages that may result to either you or your television from the following of the instructions on this page. Please feel to message me or give me a call if you have any question regarding the repair of your TV! Thank you! 03.gif Dave All TV Repair Cell # 1-503-432-9904 pleasefixitdave@yahoo.com
Posted on Feb 23, 2009
  • Robb Aug 29, 2013
    Dave, you're awesome! I was following another post about getting rid of the green snow-like dots and hit a wall when I noticed there was not adjustment dial labeled VSCAN as the other post indicated. That's when I found this post, which is way more straight forward and actually covered my Hitachi 42EDT41. The VR1 knob was all I had to adjust. In my case, I turned it counter-clockwise - a tiny bit at a time - and it improved, but not completely. I, then, turned it back to the original position (where I had marked it) and it was perfect!
Hitachi 50 inch plasma tv gets bunch of green dots after it warms up
Sustain drivers can make this kind of fault. Panel too tshould suspected. Check the site linked below and see the illustraations there. There are illustrations of faulty plasma display panels, which can't be included by this window. Check it and see which type of fault to your TV resemble with. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Nov 28, 2012 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Green dots
A cold solder or bad electrolytic capacitor may cause some isue like this. but better leave as is for now.
Aug 12, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Blue dots on my tv screen
The model indicated is a Plasma set and if blue dots in motion (moving) may be either on the MAIN board (processes all signal) or it is even possible to be a problem on the power supply board.
Most likely a shop repair as someone would have to look, order board/s and actually replace them to find which board is bad.
This is the nature of repairs in all Plasma sets.
Only boards are sold and no individual parts.
Mar 22, 2012 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Instuction maual for hitachi plasma tv model no P50X01AU
These are the only manuals available. Maybe one of them will help.
  • Hitachi P60XR01U manual for Plasma TV
  • Hitachi P60XR01E manual for Plasma TV
  • Hitachi P60X901 manual for Plasma TV
  • Hitachi P55T551 manual for Plasma TV
  • Hitachi P55H4011 manual for Plasma TV
  • Hitachi P55H401 manual for Plasma TV
  • Hitachi P50XR01U manual for Plasma TV
  • Hitachi P50XR01E manual for Plasma TV
  • Hitachi P50X902 manual for Plasma TV
  • Hitachi P50X901 manual for Plasma TV
  • Hitachi P50V702 manual for Plasma TV
  • Hitachi P50V701 manual for Plasma TV
  • Hitachi P50TP01UA manual for Plasma TV
  • Hitachi P50TP01U manual for Plasma TV
  • Hitachi P50TP01EA manual for Plasma TV
  • Hitachi P50TP01E manual for Plasma TV
  • Hitachi P50T501A manual for Plasma TV
  • Hitachi P50T501 manual for Plasma TV
  • Hitachi P50T01UA manual for Plasma TV
  • Hitachi P50T01U manual for Plasma TV
  • Hitachi P50T01EA manual for Plasma TV
  • Hitachi P50T01E manual for Plasma TV
  • Hitachi P50S602 manual for Plasma TV
  • Hitachi P50S601 manual for Plasma TV
  • Hitachi P50H401A manual for Plasma TV
  • Hitachi P50H4011A manual for Plasma TV
  • Hitachi P50H4011 manual for Plasma TV
  • Hitachi P50H401 manual for Plasma TV
  • Hitachi P50A402 manual for Plasma TV
  • Hitachi P50A202 manual for Plasma TV
  • Hitachi P42TP01U manual for Plasma TV
  • Hitachi P42TP01E manual for Plasma TV
  • Hitachi P42T501A manual for Plasma TV
  • Hitachi P42T501 manual for Plasma TV
  • Hitachi P42T01UA manual for Plasma TV
  • Hitachi P42T01U manual for Plasma TV
  • Hitachi P42T01EA manual for Plasma TV
  • Hitachi P42T01E manual for Plasma TV
  • Hitachi P42H401A manual for Plasma TV
  • Hitachi P42H4011A manual for Plasma TV
  • Hitachi P42H4011 manual for Plasma TV
  • Hitachi P42H401 manual for Plasma TV
  • Hitachi P42H01U manual for Plasma TV
  • Hitachi P42H01E manual for Plasma TV
  • Hitachi P42A202 manual for Plasma TV
  • Hitachi P42A01 manual for Plasma TV
  • Hitachi CL42PD2100 manual for Plasma TV
  • Hitachi CL37PD2100 manual for Plasma TV
  • Hitachi CL32PD2100 manual for Plasma TV
  • Hitachi 70VX915 manual for Plasma TV
  • Jan 31, 2011 | Cell Phones
    Green vertical line on right side of my 42"hd hitachi plasma
    you need to replace the ABUS-L-PWB on the left side about $75 for part.
    Sep 03, 2009 | Hitachi 42HDM12 42 in. Plasma Television
    Hitachi Plasma EDTV has green dots flickering all over screen
    that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
    Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
    Vertical lines on screen
    1. Frist on the BURN MODE.
    2. Check whether same
    Vertical lines on screen ?? 3. If yes ..?
    4. Then change the LOGIC BOARD or PDP
    Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
    When I turn my hitachi plasma tel on I see lots of green dots all over the screen is this an adjustment problem or a part going out
    I had the same problem with my Hitachi 42edt41. It was the Y sustain pcb. Large board on the left as you are looking at it from the back. Costs about $750. for the part.
    Bill
    Dec 14, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
    42EDT41 colored snow/pixels
    I have the same green dots that are seen especially when the bacground picture is dark or black. Mine does not seem to be changing when it warms up, and I also get it on my digital cable as well as on any DVD's I play. Please help with any advise. I think it was always there, but I assumed that a dgital cable upgrade would fix it - I should have known better...
    Thanks a bunch in advance...
    Oct 22, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
    Hitachi 42edt41green static
    Dave you know your stuff man !!! You helped me fix my black line fix on my LCD / Plasma and then now you helped me get rid of my green dots on my screen !! You rock . thanks a Million
    Aug 07, 2008 | ViewSonic N3251w 32 in. LCD HDTV
    Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
    987 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
