My akai cyclone cannister vacuum cleaner model VC-TB 3016 has a rug beater brush that is not rotating or beating. We tried cleaning the filter. what else could be the problem?
VacuumRepair
  • 438 Answers
SOURCE: Rug Beater isn't rotating during use
This defintiely sounds like your belt has broken or slipped off the motor pulley. The brushes on your vacuum are driven by a belt that attaches to the motor shaft on one end, and the roller brush on the other end.
If you really do have the Bissell 6594 model that you posted this repair under, then to check your belt, simply turn the vacuum upside down, and remove the four screws from the plate that covers the brushes. The bottom plate will then lift off, and you will have access to the brush and belt area of your machine.
You'll probably notice that the belt is either split completely, or is stretched out, and fallen off the motor shaft. Even if the belt is still completely circular, it may be a good idea to go ahead and replace the belt anyway. We recommend replacing the belt on your vacuum every 6 months even if they don't break, as they don't perform nearly as well when the machine has a fresh, tight belt on it.
The model 6594 uses the Bissell Style 7,9,10, etc. belt. It's the most popular Bissell belt on the market. If you don't already have a new belt handy, here's a link to your belt on our website if you need to purchase one:
Bissell Style 7/9/10/12/14/16 Upright Vacuum Cleaner Belts (2 Pack), Part Number 32074
Here's link to the Bissell Owners Manual for your model that will walk you through step by step how to replace the belt on your machine:
http://www.bissell.com/searchresults.aspx?searchtext=6594 &mode=userguides
I hope that this was helpful. If you have any further questions or concerns, please feel free to use the clarification request form here on Fixya, and I'll be happy to answer any of your follow up questions.
If this was helpful, please be so kind and rate the repair, or leave feedback, this is greatly appreciated by the Fixya community when a helpful answer is written.
Chris Jones
GoVacuum.com
Posted on May 28, 2010
  • 377 Answers
SOURCE: How do you get the beater brush to start rotating,
Sounds like the rubber drive band has not been replaced properly to drive the brush and/or the brush was not properly cleaned. You can find the manual here:
http://dl.owneriq.net/4/4d79dca8-65d8-4c46-a58a-a2fef1f89635.pdf
Posted on Sep 14, 2010
  • 1833 Answers
SOURCE: The rug roller or brush stoped rotating. I have
First try the reset button. That is located on the left ofthe brush bar unit as you look at the machine. It is red. Press it and see ifthe brush bar works when the machine is reclined then. If it doesn't,check the belt whether it is broken. If you found it broken then you need tobuy a new drive belt assembly. If the belt is ok, then you most likely need a brushbar motor. Apart from this you can visit http://media.dyson.com/downloads/us/floorcare/manuals/dc24_opmanual_usa.pdf.This may help you further.
Posted on Jun 03, 2011
#1 Taper
  • 1041 Answers
SOURCE: My Dyson vacuum cleaner beater-bar
Try my Tip on this problem: www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
Good Luck!
Jim
Posted on Aug 10, 2011
  • 35 Answers
SOURCE: Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Posted on Apr 09, 2013
I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brushes do not disengage when in upright position
Set the brush control, as needed. The brush control turns the brushbar on the underside of the vacuum on and off. The button is located beside the power button, on the top-front of the vacuum cleaner. Turn on the brush control for cleaning carpet. Turn off the brush control for bare floors or delicatelb_icon1.png rugs..
Feb 25, 2013 | Dyson DC15 All Floors - The Ball Bagless...
The brushes stop rotating on rugs after a few seconds then button has to be pressed to start rotating again but keeps cutting out
Not sure this is your foolproof solution to the problem, but you might give it a try to see if it solves your problem.
When the beater brush starts to bind up due to debris it retards the action of the cleaner, sometimes to the point of the belt breaking.
Remove the beater brush as if you were going to change the belt. Remove all debris and clean as best you can. Pay attention to the end pieces on each end of the beater brush. They will can clogged to the point to stopping the brush from rotating. Add some WD40 to the clips at the end of the beater brush and work in by twisting the clips while holding the beater brush. Once it seems to be free, reassemble and be sure the belt is on properly, you might want to consider replacing the belt.
If you find this solution to be of help I would appreciate a Thumbs Up. Good luck and be well. Paul
Oct 06, 2010 | Dyson Vacuums
When i vacuum the dirt and particles are not going into the windtunnel container-appears to be cleaning floor but isnt making it into the container.filters are checked and cleaned.less than 6 months old
If there is no obvious clog in the unit, you might want to check the beater brush and the drive belt. Be sure the belt is not broken and be sure the beater brush is free enough to rotate. If there is a broken belt it will be obvious.
I suggest you remove the beater brush and clean it as best you can, add some WD40 at each end by the brush holders and reassemble.
I would appreciate a Thumbs Up rating on this if you find my solution to be beneficial.
Oct 05, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
How do you get the beater brush to start rotating, the dyson was just cleaned and the beater brush won't rotate
Sep 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Where is the belt located?
The "belt" is normally the drive device that turns the beater brush found on the bottom front of the vacuum. Its purpose is to beat the rug and cause dirt and debris to rise up from the carpeting and be sucked into the vacuum. If the belt is missing, you may not see it. If the belt is in place, it will loop around the beater brush and back to a drive motor. Since belts can break on a regular basis any covers over it should be easy to remove via small slide levers or at most by removing a few screws from the bottom of the vacuum. The new belt must be attached properly in order for the brush to move in the correct direction. If you are going to replace the belt it is probably a good time to clean the beater brush and lubricate the end pieces of the brush with some WD40 as well.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
Bare floor selection still rotates brushes
Your switch should have 2 different on positions. One for simple suction and one to engage the beater. The setting without the beater being engaged should be first position from off and the beater would be second position
Jan 20, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover Vacuum
Our Hoover upright vacuum cleaner makes a very loud noise when it is running. What causes this?
Jun 28, 2006 | Hoover S3614 Vacuum
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
