Question about Kyocera Mita FS 3800 Laser Printer
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is no paper jam. we turn off and turn on the printer but the problem still remain same. so now we request you to solve our problem soon. we shall be very thank full of you.
  • 200 Answers
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Posted on Apr 15, 2011
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
I have a continous red light (paper jam) on a kyocera Mita fs 1000+ not obvious paper jam,..... what's wrong?
If you are not seeing any paper there you most likely have a bad paper detect sensor. The paper detect sensor is what looks for the proper timing of the paper moving through the machine and indicates a jam when the paper stops.
Dec 24, 2010 | Kyocera Mita FS-1020D Laser Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
Paper jammed between 2 red rollers in the back, can;t dislodge
The red rollers are probably replaceable, and therefore removable. Take a close look, and see if you can tell how they would be removed. It will either snap out, or you'll push it to the side and remove one end at a time. It'll be easier to pull the paper without the roller in the way.
While you have the roller out, you can clean it by wrapping packing tape around it a few times.
Jan 03, 2010 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS 1920 paper jam
Please install printer cartridge with drum unite properly.
Aug 24, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS 3800 :I get one message:Open the rear unit and remove the paper. Then pull the green lever and remove the paper. Check for paper inside from the rear and remove the paper. So i just make...
the green lever it is referring to is on the front if you pull out the tray. it is your conveying unit. sounds as if you have a paper bit bit stuck in a sensor or a broken sensor.do you have a rectangular piece on the back of the printer that pulls out? that would be your duplexing unit (there are a couple sensors there too) sensors are black and should move back and forth freely when touched with your fingers.
Aug 04, 2009 | Kyocera Mita FS 3800 Laser Printer
Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
Apr 29, 2009 | Kyocera Mita FS 3800 Laser Printer
Kyocera FS 3800 printer - error code F3 any ideas!!!!
Technical Support You may contact Kyocera Technical Support Monday - Friday 9 am - 6 pm EST at:
1-800-255-6482
Jan 26, 2009 | Kyocera Mita FS 3800 Laser Printer
Kyocera 3820DN
If the neck of the waste toner box has toner on it it will think it is full wipe inside of neck stem with tissue.
Turn off and on, does waste message disappear? If it does and you still have jam problem post back and I will help you solve it too
Dec 02, 2007 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
449 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
